por73914 |
I don't know what the hell I am doing... ![]() ![]() Group: Members Posts: 349 Joined: 10-April 07 From: Fayetteville, AR Member No.: 7,660 ![]() |
The 914 I just bought has the reflector on the back with a solenoid release. The solenoid does not work. Any idea on how to get the trunk open?
Thanks Paul |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
First check under the car, above the muffler, hopefully a PO installed an emergency pull wire of some type. If not lots of extensions, pop the plug and get to the latch bolts through the engine bay.
por73914 |
First check under the car, above the muffler, hopefully a PO installed an emergency pull wire of some type. If not lots of extensions, pop the plug and get to the latch bolts through the engine bay. Man that would be LOTS of extensions... (IMG:style_emoticons/default/headbang.gif) |
Mark Henry |
First check under the car, above the muffler, hopefully a PO installed an emergency pull wire of some type. If not lots of extensions, pop the plug and get to the latch bolts through the engine bay. Man that would be LOTS of extensions... (IMG:style_emoticons/default/headbang.gif) Yep...but it can be done. |
Lo-Fi Version | Time is now: 22nd June 2024 - 07:37 PM |
