level914 |
Member ![]() ![]() Group: Members Posts: 68 Joined: 2-November 03 From: Sparks, Nv Member No.: 1,300 ![]() |
Just needed to tell someone that I did my very first valve adjustrment. My wife isn't very impressed but she doesn't know what was involved.
Following a threrad from a couple days ago I set them all to .005. I have a 76 2.0. If any body knows of a problem with this please let me know. I know most of you probably do these adjustments all of the time, so it's no big deal. I'm just feeling super proud of myself and had to share it. Anyway, I triple checked my work and no leaks through the new gaskets. O.k. my harm hurts from patting myself on the back now. Although not as bad as my hands hurt from all of the new cuts and gashes from the adjustment. Now on to the timing. I think she's pretty close now. Any tricks or advice on the timing would be appreciated. Thanks. |
nebreitling |
Member Emeritus ![]() ![]() ![]() ![]() Group: Members Posts: 3,314 Joined: 26-March 03 From: San Francisco Member No.: 478 ![]() |
way to go!
re. timing, it's quite simple (much simpler than valves). there's an article @ pelican for it. the only thing i would add is to repaint your timing marks -- make the mark big and bright and visible such that you don't have to lean over the engine too much. and don't forget to disconnect and plug the vacuum hose(s). i always stand on the drivers side with my arms semi-crossed; timing light in right hand, throttle cable in left, tach sitting on the air box. check the timing at 3500, adjust distributor, check the timing at 3500, adjust, etc. etc. n |
Lo-Fi Version | Time is now: 26th June 2024 - 12:26 AM |
