> Home made tools, Show us yours
Bartlett 914
post Jan 8 2009, 09:21 AM
We all do it. We sometimes need a tool for a special use. It sometimes makes the difference in how well a job comes out Earlier this year, just for the heck of it, I removed the shaft from the bushings in an old trailing arm. I ended up using heat. I did get it out but what a an awful stinky mess! Yesterday Glenn (gms) stopped by with 2 trailing arms he was cleaning up. He wanted to know if I had a press for the job. With a little scrap metal some machining and welding we came up with a simple tool to remove the shaft. Here are a couple pictures of what we came up with. The tool worked really nice. I think if wanted, this would also work with the trailing arm in the car.
So how about posting some of the special tools you have made.
majkos
post Feb 1 2009, 09:59 AM
I'm suprise no one made a Engine Head Sensor tool.
Let's step over to the tool box (IMG:style_emoticons/default/rolleyes.gif)
Bartlett 914   Home made tools   Jan 8 2009, 09:21 AM
URY914   I kinda like by engine crossbar wheels. It's n...   Jan 8 2009, 09:44 AM
Bartlett 914   I kinda like by engine crossbar wheels. It's ...   Jan 8 2009, 09:52 AM
marks914   Here is my version of the engine installation tool...   Jan 8 2009, 10:48 AM
Dr Evil   I removed my /6 and tranny together last night and...   Jan 8 2009, 10:56 AM
aircooledtechguy   Here's a couple things: The first is a super ...   Jan 8 2009, 11:13 AM
Bartlett 914   Here's a couple things: The first is a super...   Jan 8 2009, 11:22 AM
aircooledtechguy   I like your soda blaster. For cleaning the carbur...   Jan 8 2009, 01:50 PM
SGB   Yeah Nate, that extended plug socket is good. I d...   Jan 8 2009, 11:27 AM
Jeff Bowlsby   My D-Jet break-out box:   Jan 8 2009, 02:30 PM
Bartlett 914   My Brake bleeder. Probably the simplest of tools b...   Jan 8 2009, 03:19 PM
HAM Inc   Those are some neat tools! I really like the a...   Jan 8 2009, 04:06 PM
scotty b   My English wheel and my shrinker / stretcher I con...   Jan 8 2009, 06:54 PM
r_towle   B)-->
QUOTE(scotty b @ J...   Jan 8 2009, 08:12 PM
scotty b   some guy on E-bay seveal years ago. I really don...   Jan 8 2009, 08:17 PM
URY914   I made an extension for my floor jack. When I jack...   Jan 8 2009, 07:09 PM
URY914   I welded a old socket on the bottom of it to go in...   Jan 8 2009, 07:10 PM
URY914   I also get comments on the jack stand blocks. Who ...   Jan 8 2009, 07:12 PM
URY914   I build this tool box/welding cart too...   Jan 8 2009, 07:16 PM
URY914   The frame in made of scrap Unistrut steel from a j...   Jan 8 2009, 07:19 PM
URY914   I found these bad boys at a auto show and really w...   Jan 8 2009, 07:23 PM
smontanaro   Can we just skip the obligatory waiting period and...   Jan 8 2009, 07:37 PM
Todd Enlund   Can we just skip the obligatory waiting period an...   Jan 8 2009, 07:59 PM
911quest   Here is my work in progress a P258c for seting pin...   Jan 8 2009, 07:45 PM
Dr Evil   Here is my work in progress a P258c for seting pi...   Jan 8 2009, 07:46 PM
Zimms   Here is my work in progress a P258c for seting pi...   Jan 9 2009, 08:36 PM
911quest   Here is my work in progress a P258c for seting p...   Jan 10 2009, 09:31 PM
Zimms   [quote name='Zimms' post='1119775' date='Jan 9 20...   Jan 10 2009, 11:22 PM
r_towle   I want a plasma cutter...my head hurts thinking ab...   Jan 8 2009, 08:20 PM
scotty b   Yeah most likely overkill as I used 3/8 plate for ...   Jan 8 2009, 08:24 PM
RJMII   http://inlinethumb26.webshots.com/43161/2593686280...   Jan 8 2009, 11:53 PM
wertygrog   here's a super flat 22mm wrench for tensioning...   Jan 8 2009, 11:57 PM
zambezi   Heres an engine stand I built for storing and runn...   Jan 9 2009, 01:18 AM
Bartlett 914   Heres an engine stand I built for storing and run...   Jan 9 2009, 08:51 AM
zambezi   Heres an engine stand I built for storing and ru...   Jan 11 2009, 12:26 AM
michelko   My Engine Test stand and the tool to check fuel...   Jan 9 2009, 08:58 AM
Todd Enlund   and the tool to check fuellevel in zenith carbs ...   Jan 9 2009, 12:50 PM
aircooledtechguy   Here's my engine run stand and the starter box...   Jan 9 2009, 11:25 AM
andys   I've got several custom jigs and fixtures, but...   Jan 9 2009, 02:56 PM
roadster fan   I've got several custom jigs and fixtures, bu...   Jan 9 2009, 04:16 PM
MrKona   Here's my transaxle driveshaft holder tool. Ke...   Jan 9 2009, 03:19 PM
roadster fan   Here is one that I made after having to remove the...   Jan 9 2009, 04:37 PM
914dave   Here's the rotisserie pix's   Jan 9 2009, 05:15 PM
J P Stein   Wanna check backlash on the R&P of your 901? H...   Jan 9 2009, 07:34 PM
MrKona   Wanna check backlash on the R&P of your 901? ...   Jan 9 2009, 10:23 PM
J P Stein   I like the backlash measurement set up. Do you ...   Jan 10 2009, 10:47 AM
carr914   This thread would not be complete without FourBlad...   Jan 9 2009, 09:32 PM
sean_v8_914   suspension bushing reamer   Jan 10 2009, 10:09 AM
rick 918-S   I made these for doing large deep shrinks. You sli...   Jan 10 2009, 01:57 PM
rick 918-S   Here is the result or close to it.   Jan 10 2009, 01:57 PM
McMark   Revival! I found a tool I made awhile ago. 9...   Jan 19 2009, 09:53 PM
highways   Here's my favorite 'found object'. My ...   Jan 20 2009, 03:49 AM
Dr Evil   Here's my favorite 'found object'. My...   Jan 28 2009, 04:46 PM
McMark   That's a cool kit!   Jan 20 2009, 08:46 PM
URY914   No, it's a TOOL kit.   Jan 20 2009, 09:23 PM
MrKona   Here's my home made blasting cabinet. I just f...   Jan 28 2009, 01:13 AM
Todd Enlund   Here's my home made blasting cabinet. I just ...   Feb 1 2009, 11:35 AM
cwpeden   I made my own blasting cabinet too and used my sho...   Jan 28 2009, 01:41 AM
scotty b   Yeah you really can't beat Thompsons prices bu...   Jan 28 2009, 06:44 PM
rick 918-S   I'm not sure if you would classify 2" mas...   Jan 30 2009, 08:39 AM
highways   I couldnt resist this deal on the cigars, but be...   Jan 30 2009, 06:51 PM
zig-n-zag   tranny nut buster.... http://i631.photobucket.com/...   Jan 31 2009, 07:48 PM
majkos   I'm suprise no one made a Engine Head Sensor t...   Feb 1 2009, 09:59 AM
majkos   Simple 13mm socket, 914 jack handle, cut at a ...   Feb 1 2009, 10:20 AM
Sleepin   ......and I am missing your Superbowl party.... :W...   Feb 1 2009, 11:15 AM
Gint   You've never been to Kevin's?!?! ...   Feb 1 2009, 11:22 AM
majkos   You've never been to Kevin's?!?! ...   Feb 1 2009, 02:16 PM
Wilhelm   [size=5]Ball Joint Remover [center]So I don...   Feb 2 2009, 10:11 PM
McMark   Nice work.   Feb 3 2009, 12:49 AM
Racer Chris   Delrin rear bushing cutting tools Top: Sleeve th...   Feb 5 2009, 09:23 AM
larss   Rear boot torsion bar tool Made this tool for fit...   Sep 22 2009, 01:15 AM
charliew   I don't remember where I saw it but the fiero ...   Sep 22 2009, 08:24 AM
jimkelly   bearing removal tool - not mine see thread http...   Apr 28 2010, 07:21 AM
McMark   Made another tool today. This piece fits tightly ...   Jul 28 2010, 02:01 PM
rdauenhauer   Here is one that is surprisingly simple but I find...   Jul 30 2010, 09:35 PM
rdauenhauer   here is THE tool for unlocking the rear boot :D ...   Jul 30 2010, 09:37 PM
Jeff Bowlsby   here is THE tool for unlocking the rear boot :D ...   Aug 12 2010, 01:07 PM
charliew   here is THE tool for unlocking the rear boot :D...   Aug 13 2010, 05:34 PM
charliew   A picture of you using that tool would be interest...   Jul 31 2010, 01:05 PM
larss   Handle made when fitting the rear window, one in e...   Aug 12 2010, 02:50 AM
McMark   :lol4: Love it, Lars! That's awesome.   Aug 12 2010, 11:22 AM
Richard Casto   :lol4: Love it, Lars! That's awesome. ...   Aug 12 2010, 01:13 PM
Phoenix-MN   Let's kick it up a notch This isn't 914 ...   Aug 12 2010, 06:23 PM
charliew   That is neat but it would take me three days to bu...   Aug 13 2010, 05:27 PM
Bartlett 914   That is neat but it would take me three days to b...   Aug 13 2010, 05:33 PM
rick 918-S   That is neat but it would take me three days to ...   Aug 14 2010, 02:42 PM
Phoenix-MN   That is neat but it would take me three days to b...   Aug 14 2010, 02:31 PM
qa1142   [quote name='charliew' post='1356147' date='Aug 1...   Aug 14 2010, 02:40 PM
rudedude   I'd even pay you something for your time :tro...   Aug 14 2010, 03:00 PM
qa1142   that is the $25 I would even add a paypal fe...   Aug 14 2010, 03:06 PM
charliew   I would think 300.00-500.00 might cover the labor   Aug 14 2010, 03:09 PM
Phoenix-MN   I would think 300.00-500.00 might cover the labo...   Aug 14 2010, 05:15 PM
qa1142   [quote name='charliew' post='1356452' date='Aug 1...   Aug 14 2010, 05:22 PM
sixnotfour   Towing aid without removing axles.   Aug 28 2010, 05:56 PM
Dr Evil   That looks dangerous :blink:   Aug 28 2010, 07:03 PM
John   First pic shows: 914 Rotisserie Engine stand My...   Aug 28 2010, 09:06 PM
rick 918-S   I had a very rusty caliper I made this clamp with ...   Sep 21 2010, 10:43 PM
rick 918-S   :)   Sep 21 2010, 10:44 PM
rick 918-S   :)   Sep 21 2010, 10:46 PM
rick 918-S   :)   Sep 21 2010, 10:48 PM
35 User(s) are reading this topic (35 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 27th December 2024 - 07:12 PM
