Scott S |
Small Member ![]() ![]() ![]() Group: Members Posts: 1,697 Joined: 30-April 03 From: Colorado Member No.: 633 ![]() |
Hi All -
Was at a Superbowl party where a pal showed up in an older, fairly beat 928. We started tinkering but primarily just did some cleaning. It was a nice day, so we did some degreasing of the motor - it actually came out pretty darn nice. As I was wiping off the intake, I took a small wire brush around the silver Porsche crest located on the top just to get some last remaining yuck out of the pours of the intake. I didn't even get the chance to actually scrub - the crest came off with litterally no pressure. It is not a mechanical fit and you can see the remnance of some type of clear/yello epoxy. I felt terrible. Will something like JB weld work to repair this? Any other suggestions? I am concerned about the heat. I dont want to add to this guys pain by having this crest fall into the belts later on -although it was pretty clear that this was close to happening already. I just used Simple Green to clean the thing - I cant imagine that would have eaten away at that epoxy. Here is a pic. Thanks - Scott S Attached image(s) ![]() |
mightyohm |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,277 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest ![]() ![]() |
I think it would be worth a try. JB Weld is rated to very high temperatures.
You have to clean everything very thoroughly first. If both surfaces are somewhat porous that should give the JB Weld more "bite". |
Lo-Fi Version | Time is now: 28th June 2024 - 11:51 PM |
