GaroldShaffer |
You bought another 914? ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 7,624 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None ![]() ![]() ![]() |
I have two 74 1.8 pars cars (I know, its a sickness) both cars are beyond running, but the air flow sensor looks to be in great shape. I would like to verify that they are working and other than installing them on a running 1.8 how can I test them?
yes I plan to sell them, but I don't want to sell non working parts. Thanks |
ejm |
I can see the light at the end of the tunnel ![]() ![]() ![]() ![]() Group: Members Posts: 2,695 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None ![]() |
Inside the AFM there is a fixed resistance, a variable resistance and a switch. With an ohm meter and a diagram these components can be tested. The switch should close when the flap is opened slightly and the resistance should vary smoothly. The Dr. pointed out the common mechanical failure. On the electrical side the usual failure is wear of the wiper components causing bucking or flat spots. If the black cover has been removed someone may have tried adjusting it and it may never be right again.
Lo-Fi Version | Time is now: 25th June 2024 - 09:18 PM |
