I received Army Dudes car yesterday, Work starts to blend two cars |
burton73 |
Feb 3 2009, 10:44 PM
burton73 Group: Members Posts: 3,569 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
I received Army Dudes car on Monday and now I am going drop the engine and trans and cut out the bracing from this car with the plan to blend it the Duc’s Blue car that will be in a few days. It will take a long time but I will get rid of this body after I have pulled off the good parts.
I wanted the club members to see what I was up to and ask if they see any problems with this. I want to end up with a car with a rear floor in the trunk and it looks like I can cut and raise a section above the center of the 930 trans. with fasteners to service the box when I need to and still fit a space saver on a Fuchs (I tried it today.) I was told if I use a smaller distributor I would not need to get clearance at the front wall of the trunk. Someone in the V8 know may answer that for me if you can. The stock 914 motor mounts look like they just had a plate welded on and I would like to know if you think that will be OK for 400HP. The pictures show the custom motor mounts set up and the welded brackets. The car came with a Ron Davis Renegade radiator. The Blue car will end up with Boxster brakes and a Carrera front end. 7” 16 Fuchs stock body that is all pained now with new black leather interior. Thanks for your help as always, Bob |
burton73 |
Feb 4 2009, 11:08 PM
This is where it is all going
What is the story on the size of the distributor and the need to cut the trunk? |
Lo-Fi Version | Time is now: 29th June 2024 - 12:21 AM |
