M.S.D Box, good or bad |
6freak |
Feb 5 2009, 01:50 PM
MR.C Group: Members Posts: 4,740 Joined: 19-March 08 From: Tacoma WA Member No.: 8,829 Region Association: Pacific Northwest |
I have one in the shop..the ? is is it worth the effort to install ,where the best place,and is it hard to do ..mind you I`m electrically challenged so be gental |
jt914-6 |
Feb 5 2009, 02:39 PM
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
I've used a MSD for years and like it. Some will say they like them and some will not. I use a 6AL. It has an adjustable rpm chip slot. A chip kit for example goes from 6,000 to 7,000 in increments of 200 rpm. (6,000, 6,200, 6,400 and so on).
It gets an incoming signal from the points or electronic pickup, depending on which dist. you have. Two wires go to the coil. It is easy to connect and mount. I mounted it in the engine compartment on my last 914-6. On my current project six, I'm mounting it behind the passenger's seat as seen in the pic. I would suggest if you use one that you match it with the MSD Blaster coil, use 7 or 8mm wires, and gap the plugs to 32-36 range. You may have to also use one of their tach adaptor. If you are using a points type dist., you may want to use a Petronix Ignitor or other electronic points replacing device. Attached image(s) |
Lo-Fi Version | Time is now: 26th September 2024 - 05:29 PM |
