> Could this be my problem?, Anybody else old enough to remember "Heathkit"?
Porsche Rescue
post Feb 7 2009, 02:38 PM
Saving and Enjoying Old Porsches
I posted last fall about my problem: '70 D-jet, extremely hard to start, requires much throttle goosing to keep it going. Once it is fully warmed up it runs great.
I assumed FI problem and have checked everything. All seems OK. Bleysing and others suggested weak spark. Good enough for warm engine, but inadequate for cold. (Frankly, ignition is the weakest category in my 914 skillset). I have checked all connections, grounds etc. All seem OK.
Then, a light bulb! My car has a Heathkit, vintage capacitive discharge ignition (I have no clue how it works or what it does, see skillset deficiiency above). I do know it is over 30 years old. Could that be my problem? Can I just disconnect the 4-wire harness from the coil? Or do I need to do some other re-connecting.
Here is the earlier thread on my problem:
http://www.914world.com/bbs2/index.php?sho...p;hl=hard+start
All ideas welcome!
Spoke
post Feb 7 2009, 11:05 PM
Jerry
Cold problems could be head temperature sensor. Have you checked resistance at room temp & hot temp? A low resistance from the CHT sender will make the ECU think the engine is warm.
r_towle wrote:
_____________________
Lean means vacuum leak.
I though with D-Jet that vacuum leak will make it run rich since the MPS sees low vacuum making the ECU think the throttle is open and thus widening the injector pulses.
r_towle
post Feb 8 2009, 11:02 AM
Custom Member
QUOTE(Spoke @ Feb 8 2009, 12:05 AM) *
When running on the idle circuit the air/fuel map is hard coded.
It takes no input from the mps...
So, more air just makes it run lean..thus stalling.
Rich
Porsche Rescue   Could this be my problem?   Feb 7 2009, 02:38 PM
jmill   I've got a Heathkit dwell meter and AFR meter....   Feb 7 2009, 02:46 PM
70Sixter   You can check the spark visually by removing plugs...   Feb 7 2009, 03:16 PM
GeorgeRud   I used to love building the Heathkit electronics. ...   Feb 7 2009, 03:23 PM
Porsche Rescue   I have done a thorough "Brad Anders" FI ...   Feb 7 2009, 03:37 PM
Bartlett 914   I have done a thorough "Brad Anders" FI...   Feb 7 2009, 03:56 PM
markb   If the coil is in question, replace it. My Dad bu...   Feb 7 2009, 03:42 PM
Porsche Rescue   I checked Anders chart and I have the original eng...   Feb 7 2009, 04:00 PM
r_towle   I posted my thoughts in the other thread... RIch   Feb 7 2009, 04:09 PM
Porsche Rescue   Well damn, I disconnected the CD.......no change. ...   Feb 7 2009, 06:51 PM
r_towle   Did you read the other thread? Its about your FI q...   Feb 7 2009, 06:57 PM
Porsche Rescue   Thanks Rich. I will have a look at the TPS next, t...   Feb 7 2009, 07:01 PM
r_towle   lean idle condition. Lean makes it run like crap w...   Feb 7 2009, 07:03 PM
Porsche Rescue   TPS, then I will follow your vacuum check procedur...   Feb 7 2009, 07:09 PM
r_towle   I chased this same thing on mine.. I did the intak...   Feb 7 2009, 07:21 PM
underthetire   Hey, im looking at the same thing right now. Sitti...   Feb 7 2009, 07:24 PM
Gint   I remember. Next thing you know you'll have m...   Feb 7 2009, 10:14 PM
Spoke   Cold problems could be head temperature sensor. Ha...   Feb 7 2009, 11:05 PM
r_towle   Cold problems could be head temperature sensor. H...   Feb 8 2009, 11:02 AM
effutuo101   I remember. Next thing you know you'll have ...   Feb 8 2009, 10:27 AM
mikez   LIGHTLY spraying carb cleaner or Qwik Start in sus...   Feb 8 2009, 10:47 AM
7 User(s) are reading this topic (7 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 6th January 2025 - 05:01 PM
