> 914 Starter, Starter Location
show15
post Feb 3 2009, 09:59 AM
Hey. My name is Mike and im new here. Im only 17 but love cars and working on them. My dad owns a Porsche 914-4 1.8 and i want this car so bad but im about to go to college and he is saying if i dont have it running in 2 months hes going to sell it. This used to be my grandfathers and i would love to keep it in the family. it was fuel injected but my dad put a weber 32/36 dfav on it. its been sitting for about a year or so and when i try to start it it doesnt even make a sound. the lights go out when the key is turned to the start position and the stereo will stop. i wanna test the starter to see if thats the problem but i cant because i cant find it. can someone help me and tell me where the starter is?
Spoke
post Feb 10 2009, 01:34 AM
Jerry
Help us help you. Please do these simple tests and let us know what your results are:
Connect your voltmeter (If you don't have one, buy one, you'll need it again and again) POS lead on the big red wire on the starter and connect the NEG lead on the chassis, not the engine. Measure 12V.
Connect the POS lead of your voltmeter to the little wire on the starter, and connect the NEG lead on the chassis. Turn the key to start and check the voltage. This should be 12V or so.
If previous voltage is below 12V, remove the little wire from the starter and measure the voltage of the little wire to chassis when key is turned to start. If this voltage is not 12V, there is a problem with wiring or your ignition switch.
show15   914 Starter   Feb 3 2009, 09:59 AM
Johny Blackstain   Upper left side of the tranny, under the rear trun...   Feb 3 2009, 10:02 AM
show15   Upper left side of the tranny, under the rear tru...   Feb 3 2009, 10:08 AM
Joe Sharp   Hey Mike, :wttc: Yaeh what he said. The starter i...   Feb 3 2009, 10:07 AM
show15   Hey Mike, :wttc: Yaeh what he said. The starter ...   Feb 3 2009, 10:10 AM
Phoenix-MN   Hey. My name is Mike and im new here. Im only 17 ...   Feb 3 2009, 10:31 AM
Johny Blackstain   Read his original post :idea: Sounds like bad/...   Feb 3 2009, 11:03 AM
ericread   :agree: with all of the above. First of all, BE C...   Feb 3 2009, 10:42 AM
Joe Sharp   If you can still see the color of the wire it is y...   Feb 3 2009, 10:56 AM
McMark   :agree: Check battery voltage.   Feb 3 2009, 11:26 AM
Todd Enlund   Ground strap on the tranny?   Feb 3 2009, 11:45 AM
Joe Sharp   Ground strap on the tranny? Yeah Todd, most peo...   Feb 3 2009, 12:13 PM
9146986   Don't cut a hole in the trunk floor! I...   Feb 3 2009, 03:28 PM
ericread   Don't cut a hole in the trunk floor! I...   Feb 3 2009, 09:58 PM
McMark   :agree: Don't cut the floor, learn something....   Feb 4 2009, 11:44 AM
RJMII   :wttc: I agree, check the ground strap on the tr...   Feb 4 2009, 12:26 PM
Spoke   Good luck trying to keep the car in the family. Yo...   Feb 4 2009, 12:47 PM
show15   i found the starter and its pretty rusted. it look...   Feb 4 2009, 10:39 PM
ericread   i found the starter and its pretty rusted. it loo...   Feb 4 2009, 11:15 PM
show15   its only like 40 bucks but ill try that and see wh...   Feb 5 2009, 11:49 AM
show15   well i got the new starter in and the same thing i...   Feb 8 2009, 05:21 PM
Joe Sharp   You need to in stall a relay in between the igniti...   Feb 8 2009, 06:34 PM
Jeffs9146   There is a wireing diagram in this thread Startin...   Feb 8 2009, 06:54 PM
show15   thanks. where can i get one? and is it hard to ins...   Feb 9 2009, 12:25 AM
Jeffs9146   Hot start is just a saying that we use to describe...   Feb 9 2009, 12:06 PM
ericread   I just don't see this as a "hot start...   Feb 9 2009, 09:10 PM
Jeffs9146   Maybe, he said he replaced the starter so that sho...   Feb 9 2009, 11:03 PM
underthetire   LOAD TEST THE BATTERY BEFORE YOU GO ANY FURTHER...   Feb 9 2009, 11:09 PM
Jeffs9146   I figured he already did that.....lesson 101.914 T...   Feb 10 2009, 12:25 AM
Spoke   Help us help you. Please do these simple tests and...   Feb 10 2009, 01:34 AM
Dr. Roger   Help us help you. Please do these simple tests an...   Feb 10 2009, 01:47 AM
show15   ok well while i was waiting for the starter i put ...   Feb 14 2009, 03:17 PM
Dr Evil   Not exactly. If your battery will not hold a charg...   Feb 14 2009, 03:54 PM
dlee6204   I agree. Get a new battery. You won't be abl...   Feb 14 2009, 04:31 PM
- Lo-Fi Version Time is now: 31st October 2024 - 07:29 PM
