PRS914-6 |
Excellence Magazine Project 914 3.6 ![]() ![]() ![]() Group: Retired Members Posts: 1,278 Joined: 20-May 06 From: Central California Member No.: 6,031 Region Association: None ![]() ![]() |
The differences between the early (pre 73) and later Targa tops is shown below. The most significant difference is the step where the window seals attach. I suspect due to the different windows used in the 73 up cars. I'm checking that out now. The step is noticeably taller or hangs lower on the later tops.
Other differences are shown but I suspect they won't have a major impact. Thanks for those at WCR who volunteered their tops for the inspection ![]() ![]() ![]() |
Slick914 |
Member ![]() ![]() Group: Members Posts: 236 Joined: 10-June 07 From: Lorain, OH Member No.: 7,802 ![]() |
This is good information. Maybe it would be better suited in the originality forum where it might be easier to find?
My 73 has an early top according to the info here. Is it possible that my 73 came with the early top or is it certain that it was replaced at some point in time? It seams to fit pretty good. (IMG:style_emoticons/default/confused24.gif) |
dw914er |
Planning Cities ![]() ![]() ![]() ![]() Group: Members Posts: 2,365 Joined: 1-March 08 From: Yucaipa, CA Member No.: 8,763 Region Association: Southern California ![]() |
This is good information. Maybe it would be better suited in the originality forum where it might be easier to find? My 73 has an early top according to the info here. Is it possible that my 73 came with the early top or is it certain that it was replaced at some point in time? It seams to fit pretty good. (IMG:style_emoticons/default/confused24.gif) im pretty sure my 73 has an early top too... if thats the case then thats the way my car came. |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,171 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
This is good information. Maybe it would be better suited in the originality forum where it might be easier to find? My 73 has an early top according to the info here. Is it possible that my 73 came with the early top or is it certain that it was replaced at some point in time? It seams to fit pretty good. (IMG:style_emoticons/default/confused24.gif) im pretty sure my 73 has an early top too... if thats the case then thats the way my car came. '73 was a transition year. If you have a '73 with a early top, i suspect you also have the early windows and mechanism, as they go together. (IMG:style_emoticons/default/shades.gif) Andy |
dw914er |
This is good information. Maybe it would be better suited in the originality forum where it might be easier to find? My 73 has an early top according to the info here. Is it possible that my 73 came with the early top or is it certain that it was replaced at some point in time? It seams to fit pretty good. (IMG:style_emoticons/default/confused24.gif) im pretty sure my 73 has an early top too... if thats the case then thats the way my car came. '73 was a transition year. If you have a '73 with a early top, i suspect you also have the early windows and mechanism, as they go together. (IMG:style_emoticons/default/shades.gif) Andy which month was the turn around? My car was built july 73, so I suspect that august+ was the later then? |
Lo-Fi Version | Time is now: 3rd April 2025 - 05:36 AM |
