turnaround89 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest ![]() |
Just wanted to know if anyone has any opinions on the shift lockout kit, does it help? How hard is the install? For $50, it may be worth it and my reverse gear may thank me.
I have all new bushings and the shifting seems to be as good as possible for a tail shifter but every now and then i clip reverse and im getting sick of it. Will this help? Or should i just save and transform my car to side shift, don't really want to since it is the original trans still in the car and i don't want a trans sitting in the garage taking up useful space! |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,915 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
You will need to take a old screwdriver and make it into a compression tool for the springs. Kit says will require you to enlarge holes for new pins and springs. Spring compression is tricky and can be dangerous.
Lo-Fi Version | Time is now: 20th June 2024 - 06:02 AM |
