> Power steering build, MR2 Electric Pump
drive-ability
post Jan 30 2009, 07:57 PM
I'm now working on a power steering system for my V8 car. I'm using a Golf P/S unit and a Toyota MR2 electric pump. There will be some pictures soon, I'm building the bracket to mount the power rack to the 914 cross member.
I'll doc the build up in this thread.. (IMG:style_emoticons/default/driving.gif)
byndbad914
post Feb 24 2009, 10:09 PM
shoehorn and some butter - it fits
1" longer is still a pretty good amount, which means that it might be hard to get the bump out of it, but I think it is more doable at 1" than, of course, 4" like I thought before (IMG:style_emoticons/default/smile.gif)
charlie - I don't know about a stock 914 but I think it is rather low - the rack sits just above the lower arm pivot point and pivots at the same width and lines up decently with the upper mount locations, but when I built my tube chassis car I relocated the rack up, etc and have measured my bump - I have 0.005" on the first 1" of compression and an additional 0.007" on the second 1", so 0.012" overall for the max compression I expect on a race car, which is essentially what one would call "zero bump".
So, back to drive's issue, if the rack were in stock location then I can guarantee the 1" difference per side in tie rod length would have a strong effect for creating bump steer, like 1/4" in the first 2" of motion I would hazard to guess, and a street car should expect 3" of compression travel at minimum so the bump could be significant. Just being a bit off can cause 1/8" per side.
However, the rack is relocated a bit, so I dunno what effect that would have - it might be even worse. I suspect that an aggressive rack relocation and/or tie rod offset might fix it over a small range of motion but it will never be a "zero" bump setup because within just a couple inches of motion the difference in pivot locations will never want to zero out over 3" of travel (or more). But if it were an 1/8" even on 2" of compression, it isn't optimal but on a street car it probably wouldn't be that noticeable for most people (I would notice it cuz I am used to recognizing it). On a racer with really sticky and wide front tires, it would be very noticeable.
drive-ability
post Feb 24 2009, 11:25 PM
QUOTE(byndbad914 @ Feb 24 2009, 08:09 PM) *
I normally learn as I go and it seems nothing has changed (IMG:style_emoticons/default/dry.gif) I'll just have to start with evaluating the basic P/S operation. If it works well I'll relocate the rack, why should this be any different than many of my projects..
I did take some measurements using a laser, moving the wheel up and down. It looked like I had some toe in but not much maybe 1/8 inch over 6 inches or so of movement. I did mount the rack higher, closer to the body and forward a bit as well. This was a crude test / measurement at best.
Nobody said this would be easy (IMG:style_emoticons/default/hissyfit.gif)
Here is the set up I used. The laser is level and the suspension is hanging down as I jack up the control arm the laser line should twist if the toe changes. I can't see it move much. I did it a few times and didn't see any real difference, less than the thickness of the laser line for sure. I see less than I mentioned above, looks like less than 1/16 or so.
What I did see is a lot of change in caster, honestly I don't know if thats normal or a big deal.
(IMG:http://members.cox.net/altjamy/Power%20steering%20Laser%20shot.jpg)
drive-ability   Power steering build   Jan 30 2009, 07:57 PM
Wilhelm   Great, I'll be following this. I assume the g...   Jan 31 2009, 02:14 AM
drive-ability   The project is moving along, I've got the rack...   Feb 4 2009, 11:56 AM
Wilhelm   Thought you had a hydraulic clutch. Does the mast...   Feb 4 2009, 02:39 PM
drive-ability   Thought you had a hydraulic clutch. Does the mas...   Feb 4 2009, 02:54 PM
biosurfer1   and how nice is it to be able to work on your car ...   Feb 4 2009, 03:08 PM
drive-ability   and how nice is it to be able to work on your car...   Feb 4 2009, 03:52 PM
biosurfer1   I say pay an inmate $100 to file lawsuit afte...   Feb 4 2009, 04:20 PM
southernmost914   How loud is that pump? :D Steve   Feb 4 2009, 05:08 PM
drive-ability   How loud is that pump? :D Steve LOL,,, ...   Feb 4 2009, 06:46 PM
drive-ability   Here is a shot of the rack installed, I have made ...   Feb 15 2009, 12:10 AM
McMark   Cool! B) What' with the photo retouching...   Feb 15 2009, 01:32 AM
Wilhelm   Pretty darn cool!   Feb 15 2009, 01:44 AM
So.Cal.914   Slipped right freaking in there too. Doesn't l...   Feb 15 2009, 09:41 AM
drive-ability   The gas tank fits without issue. I made a steerin...   Feb 15 2009, 10:40 AM
Wilhelm   Where are you going to hide the MR2 pump? What yea...   Feb 15 2009, 03:54 PM
So.Cal.914   Where are you going to hide the MR2 pump? What ye...   Feb 16 2009, 11:20 AM
drive-ability   Posted Feb 16 2009, 09:20 AM QUOTE(Wilhelm @ Fe...   Feb 16 2009, 01:44 PM
So.Cal.914   Posted Feb 16 2009, 09:20 AM QUOTE(Wilhelm @ F...   Feb 16 2009, 06:56 PM
drive-ability   So now you can see how the units fit, its a mess, ...   Feb 19 2009, 02:26 PM
turboman808   Let me know when you make a power brake system. I...   Feb 19 2009, 02:41 PM
byndbad914   Do you intend to measure the bump steer? That wil...   Feb 19 2009, 04:31 PM
drive-ability   Do you intend to measure the bump steer? That wi...   Feb 19 2009, 09:48 PM
byndbad914   hey, I am waiting for you to science this puppy ...   Feb 20 2009, 01:55 AM
drive-ability   I have set up one tie-rod, the rack is 48" to...   Feb 21 2009, 06:12 PM
byndbad914   I have set up one tie-rod, the rack is 48" t...   Feb 23 2009, 01:14 AM
drive-ability   Here is one tie-rod, The end is 930, seems the th...   Feb 21 2009, 11:03 PM
andys   drive-ability, +1 to what byndbad914 said. Yup, ...   Feb 23 2009, 11:33 AM
drive-ability   drive-ability, +1 to what byndbad914 said. Yup,...   Feb 23 2009, 12:35 PM
Wilhelm   So the Jetta rack is 8" longer than the 914? ...   Feb 23 2009, 12:29 PM
byndbad914   ahh, misunderstood. What is the length of the new...   Feb 23 2009, 12:39 PM
drive-ability   ahh, misunderstood. What is the length of the ne...   Feb 23 2009, 12:56 PM
charliew   Someone will have to say but is the 914 perfect on...   Feb 23 2009, 10:51 PM
byndbad914   1" longer is still a pretty good amount, whic...   Feb 24 2009, 10:09 PM
drive-ability   1" longer is still a pretty good amount, whi...   Feb 24 2009, 11:25 PM
byndbad914   I normally learn as I go and it seems nothing h...   Feb 25 2009, 01:06 AM
charliew   Something a little easier might be to go to home d...   Feb 26 2009, 10:22 PM
drive-ability   I did get things going, first test drive was nice....   Feb 28 2009, 03:47 PM
Wilhelm   Doncha love when a plan comes together? :thumbsup...   Feb 28 2009, 05:34 PM
drive-ability   Doncha love when a plan comes together? :thumbsu...   Feb 28 2009, 06:11 PM
ssstikircr   :popcorn:   Feb 28 2009, 06:36 PM
drive-ability   I had time to drive it around quite a bit more an...   Feb 28 2009, 10:23 PM
Wilhelm   :bump: Just wanted to see what the long term live...   Mar 20 2009, 10:42 AM
drive-ability   :bump: Just wanted to see what the long term liv...   Mar 20 2009, 10:42 PM
Wes V   I haven't had the car aliened yet, so it can...   Mar 21 2009, 06:51 PM
drive-ability   I haven't had the car aliened yet, so it ca...   Mar 21 2009, 10:43 PM
- Lo-Fi Version Time is now: 29th April 2025 - 01:00 PM
