Instument cluster, gauges |
cvoros |
Feb 25 2009, 11:06 PM
Member Group: Members Posts: 52 Joined: 24-February 09 From: Huntsville, Texas Member No.: 10,086 Region Association: Southwest Region |
I have a 75 2.0L that has a bouncy tach. I have thought about just replacing it but also would like to know from any of you if there are any good "upgrade" replacement instrument clusters. I wouldnt mind just replacing the tach but all of the gauges are difficult at best to see at night, so I have knocked around the idea of some newer gauges.
Are there any plug-n-play clusters out there. Did a brief search tonite and didnt come up with much beyond a plate on eBay that houses standard Autometer gauges. Not even sure if any of the Autometer speedo/tachs are direct plug-ins or not. Any help would be appreciated. Pics of any "upgraded" clusters would be nice too. Although I am not a purist (obviously) I dont want anything off the wall. Something nice and simple, but better visibility/functionality would be great. Thanks in advance. (posted this over on pelican parts and havent gotten a response - hopefully have more luck here) (IMG:style_emoticons/default/biggrin.gif) |
toon1 |
Feb 26 2009, 11:44 AM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
what causes the bouncy tach.?
Spoke |
Feb 26 2009, 12:32 PM
Jerry Group: Members Posts: 7,107 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
what causes the bouncy tach.? The bounce is actually overshoot and undershoot oscillations when revving the engine or shifting. Modern tachs are damped to the point where they do not oscillate when the engine speed changes quickly. Adding a cap to the winding just dampens the response to engine RPM changes. I did this on my 74 and the tach does not bounce or oscillate at all now. The graph below shows different levels of a damped signal or movement of an arm like the tach needle. In this pic, the movement is from 1 to 0. In a 914 tach, this would be like going from one RPM level to another. The 914 tach needle oscillates and finally settles to the correct RPM. Adding a capacitor causes the needle to follow one of the damped signals. Too much cap and it is overdamped and slow to respond. Too little cap and it is underdamped and may still oscillate. Critical damping is the goal: fast response w/o oscillations. For 914 tachs, critical damping can be achieved with about 2200uF capacitor. Attached image(s) |
Lo-Fi Version | Time is now: 6th January 2025 - 04:15 PM |
