Determining total oil capacity with /6 aftermarket tank, and probably wrong dipstick |
number6 |
Feb 27 2009, 02:24 AM
Member Group: Members Posts: 352 Joined: 14-September 08 From: portland, or Member No.: 9,546 Region Association: Pacific Northwest |
OK, as it turns out, I do have a valid oil tank question! Sorry, everyone, for the multiple post changes!
What would be the best way to determine total oil capacity in my car? It is a /6 conversion with a 3.2, aftermarket oil tank (a Velios, I believe), and NO front-mounted oil cooler. I do have a Patrick Motorsport breather tank. I ask because I don't think the dipstick I have is accurate. My tank's bundled dipstick was broken, so the seller ordered me a replacement from Auto Atlanta (which appears to be a replacement for the factory tank). My thinking is to drain my oil and add back 9 quarts to see where/if it registers on the dipstick that I have. From reading through the archives, I came across this discussion: http://www.914world.com/bbs2/index.php?sho...5&hl=velios There's mention of 11 quarts max...but also 13, 14, and 15 quarts... And just to make doubly-sure: A dry sump system can't be damaged with overfills, no? Excess oil would simply drain out (through my breather tank drain) and/or burn off? Thank you for any advice! -duc |
carr914 |
Feb 27 2009, 07:32 AM
Racer from Birth Group: Members Posts: 119,246 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
OK, as it turns out, I do have a valid oil tank question! Excess oil would simply drain out (through my breather tank drain) and/or burn off? -duc And out of every nook & cranny it can force it's way out of. I had a Porsche mechanic over-fill my stock tank and the whole engine compartment was an oily mess by the time I got home. T.C. |
Lo-Fi Version | Time is now: 22nd June 2024 - 07:43 PM |
