> suby hotrod motors, Probably cost equal to a really good porsche 6
charliew
post Feb 24 2009, 09:50 AM
http://forums.nasioc.com/forums/showthread.php?t=1699103
These motors are probably 15-20k once they reach the track. Just a offhand guess. As my son has spent 13k on a street motor with no tranny mods. Just motor, ported heads, bigger cams, 100mm bore, open source tuning with datalogging and utec piggyback, bigger injectors, bigger fuel pump, bigger oil pump, front mount ic, 8qt oil pan, true cold air intake and a 30r rotated turbo at 26 psi. Conservative tune about 425awhp. Also no water or alcohol injection yet.
WRX914
post Feb 26 2009, 02:14 PM
2.5 WRX STI hybrid powered beast
Well this is a loaded question...
A hot rod suby could be as simple as mine... A brand new shortblock from Subaru of America - $1850 delivered to your door in a box that is approximately the same size as your CPU. You by yourself can easily lift the box and its crate and load it into your trucks bed. My original engine was $2K, I would figure you could buy a blown 2.0 litre for pennies on the dollar and dress the new 2.5 with the 2.0 items. I have a stock EJ20 turbo a stock ECU and when we get 100% throttle opening, I can't image what the car will do. The guys who helped me with my car (Snail Performance) can make incredible power from a Suby. Here is their direct quote off of a differnt forum...
"This car is crazy fast if we fixed it were the throttle would be 100% open the car would most likely just burn up the tires in all gears.
Thanks for the rides Keith give me a call if you need anything.
www.snailperformance.com"
I guess that says it all. I have driven some extremely fast things in my life of 40 years. Raced shifter carts blah blah blah....
This set up is extremely potent without really doing anyting to it. Not enough? No problem, slap a STOCK STI turbo (used off of NASIOC ~$250) IF that is not enough, and I seriously doubt 99% of the driving population would say that is not enough... $1400 for a fully tunable ECU and you have a completely sick ride on your hands that there is a slim chance in hell anyone could controll this power in a 914.
HERE IS THE KICKER...
If you blow it up... $1850 later a package from Subaru shows up at your door.
fiid
post Feb 27 2009, 08:10 PM
Turbo Megasquirted Subaru Member
QUOTE(WRX914 @ Feb 26 2009, 12:14 PM) *
<<chopped>>
What you said. Although - you can have a JDM longblock for sub $1000, which means I can have 2 for the price of a new one (IMG:style_emoticons/default/smile.gif)
And the fun is just silly... tee hee (IMG:style_emoticons/default/biggrin.gif)
charliew   suby hotrod motors   Feb 24 2009, 09:50 AM
cobra94563   porsche motor w/ 400+hp is more... now..an SBC...   Feb 24 2009, 10:12 AM
Vacca Rabite   porsche motor w/ 400+hp is more... now..an SBC.....   Feb 24 2009, 10:45 AM
J P Stein   Great power.... then comes the age old hot rod que...   Feb 24 2009, 10:31 AM
pktzygt   Great power.... then comes the age old hot rod qu...   Feb 24 2009, 10:37 AM
WRX914   Well this is a loaded question... A hot rod suby ...   Feb 26 2009, 02:14 PM
fiid   Well this is a loaded question... <<chopped...   Feb 27 2009, 08:10 PM
WRX914   Forgot to mention.... Because the engine complet...   Feb 26 2009, 02:21 PM
SnailPerformance   Forgot to mention.... Because the engine comple...   Mar 5 2009, 05:07 PM
DBCooper   At what point do you consider a Porsche engine to ...   Feb 26 2009, 03:14 PM
iamchappy   I may need to rethink my engine, sell my 400hp tur...   Feb 26 2009, 03:32 PM
turboman808   Yeah the subaru motor is so freakin cheap. But da...   Feb 26 2009, 03:40 PM
Brett W   Hell a 250hp 2.0 flat six is well into the 30K ran...   Feb 26 2009, 03:52 PM
DBCooper   Hell a 250hp 2.0 flat six is well into the 30K ra...   Feb 27 2009, 05:40 AM
charliew   Any suby powered 914 should be easier to handle th...   Feb 26 2009, 04:20 PM
DBCooper   I may need to rethink my engine, sell my 400hp tu...   Feb 26 2009, 04:24 PM
charliew   I see no reason to buy a renegade kit. But I like ...   Feb 27 2009, 12:11 AM
plymouth37   Subie is cheaper hands down. I have about 3K into ...   Feb 27 2009, 01:59 AM
grantsfo   Subie is cheaper hands down. I have about 3K into...   Feb 27 2009, 03:27 PM
Brett W   Turbos are the best thing for street cars. NA mot...   Feb 27 2009, 02:28 PM
turboman808   Turbos are the best thing for street cars. NA mo...   Feb 27 2009, 02:55 PM
effutuo101   I may need to rethink my engine, sell my 400hp t...   Feb 27 2009, 03:30 PM
WRX914   You do not need a aftermarket ECU. You simply nee...   Feb 27 2009, 07:22 PM
charliew   A 2.0 wrx converted to a 2.5 shortblock is called ...   Mar 3 2009, 12:02 AM
WRX914   A 2.0 wrx converted to a 2.5 shortblock is called...   Mar 3 2009, 03:05 PM
r_towle   please explain a few things. $1850 buy a shor...   Mar 3 2009, 04:11 PM
DBCooper   please explain a few things. $1850 buy a sho...   Mar 3 2009, 05:25 PM
fiid   Is it possible, or has anyone done it, to put a c...   Mar 5 2009, 04:34 PM
brant   It always comes down to priorities. try going vint...   Mar 3 2009, 04:25 PM
DBCooper   It always comes down to priorities. try going vin...   Mar 3 2009, 05:29 PM
grantsfo   It always comes down to priorities. try going vin...   Mar 16 2009, 11:23 AM
charliew   I have seen a custom itb setup on a suby but it wa...   Mar 3 2009, 10:15 PM
SnailPerformance   I have seen a custom itb setup on a suby but it w...   Mar 5 2009, 05:17 PM
charliew   [quote name='charliew' post='1141041' date='Mar 3...   Mar 14 2009, 12:44 PM
DBCooper   [quote name='SnailPerformance' post='1141879' dat...   Mar 16 2009, 06:24 AM
DBCooper   Really though as wrx914 said a good 300 hp that d...   Mar 5 2009, 05:21 PM
WRX914   I stand corrected... Charlie is correct. I calle...   Mar 5 2009, 04:20 PM
charliew   DB think about this, you are running about 80 on 3...   Mar 8 2009, 10:53 AM
DBCooper   Shift "down" to fifth? The STI engine I...   Mar 8 2009, 03:28 PM
WRX914   Last year I ran a hopped up Camaro SS that sounded...   Mar 9 2009, 01:52 PM
SnailPerformance   ill run just about anything in my car.. 505 z06 su...   Mar 9 2009, 10:41 PM
charliew   I don't know what year gsx-r1000 you are playi...   Mar 11 2009, 01:32 PM
biosurfer1   Next time I'm in Vegas, I'm going to need ...   Mar 11 2009, 01:59 PM
DBCooper   No, it's not a Gixxer, but you and a friend ca...   Mar 11 2009, 06:20 PM
charliew   Only thing I found on a nasioc search on treefroga...   Mar 16 2009, 10:53 AM
DBCooper   Only thing I found on a nasioc search on treefrog...   Mar 17 2009, 06:25 AM
biosurfer1   Holy moly....$2100/HOUR?!?!?   Mar 16 2009, 12:31 PM
grantsfo   Holy moly....$2100/HOUR?!?!? Hey th...   Mar 16 2009, 12:52 PM
charliew   I also love the sound of a flat six at 7500 but I ...   Mar 17 2009, 10:25 AM
DBCooper   No, Charlie, wasn't referring to you, it was T...   Mar 17 2009, 01:37 PM
charliew   My third, a 58 vw, was a college car to replace th...   Mar 17 2009, 02:19 PM
- Lo-Fi Version Time is now: 31st October 2024 - 07:29 PM
