> my oil/ engine problems diagnosis ?, updated, Just did compression test today 3/17/09
jsayre914
post Mar 3 2009, 04:52 PM
Speed Up !!!
take a look guys, by the way I did get her home the other night, and i beat the snow.
championgt1
post Mar 3 2009, 08:15 PM
Don't embarrass me Filmore!
How did your engine run before this mess? The stacked vacuum elbow being disconnected would have been a MAJOR vaccum leak. Is this your oil leak problem. No.
jsayre914
post Mar 3 2009, 09:28 PM
Speed Up !!!
QUOTE(championgt1 @ Mar 3 2009, 09:15 PM) *
the car ran absolutly great, even with the smoke... it is/ was fast. i used a piece of silicon inside the double stack, but im not so sure it was perfectly tight, and from what im learning there is quite a bit of pressure in my case.
jsayre914   my oil/ engine problems diagnosis ?   Mar 3 2009, 04:52 PM
jsayre914   more   Mar 3 2009, 04:54 PM
jsayre914   ...   Mar 3 2009, 04:56 PM
jsayre914   last ones   Mar 3 2009, 04:57 PM
jsayre914   Zach said he would loan me a compression tester, i...   Mar 3 2009, 04:58 PM
yeahmag   Been a while since I had FI on the car. Could you ...   Mar 3 2009, 06:51 PM
jsayre914   Could you tell if it was coming from one of the b...   Mar 3 2009, 09:22 PM
Jake Raby   Tons of blow by... Either the rings are shot or th...   Mar 3 2009, 06:54 PM
type47   Good thing a response I made didn't get posted...   Mar 3 2009, 07:09 PM
yeahmag   When combustion gases go flying past the rings the...   Mar 3 2009, 07:21 PM
Jake Raby   Bad rings can create blowby as they allow gases to...   Mar 3 2009, 07:28 PM
jsayre914   Bad rings can create blowby as they allow gases t...   Mar 3 2009, 09:24 PM
r_towle   Bad rings can create blowby as they allow gases ...   Mar 3 2009, 09:33 PM
Dr Evil   So, when are we going to rebuild your engine :) :i...   Mar 3 2009, 07:54 PM
wertygrog   My engine does the same thing when a hose falls of...   Mar 3 2009, 08:06 PM
Vacca Rabite   Hey Joe, I'm not in class this week. Next we...   Mar 3 2009, 08:10 PM
championgt1   How did your engine run before this mess? The stac...   Mar 3 2009, 08:15 PM
jsayre914   How did your engine run before this mess? The sta...   Mar 3 2009, 09:28 PM
r_towle   How did your engine run before this mess? The st...   Mar 3 2009, 09:34 PM
jsayre914   anyone know where this came from??   Mar 3 2009, 09:33 PM
r_towle   oh, the oil is from your Head vent hoses and the l...   Mar 3 2009, 09:34 PM
Vacca Rabite   oh, the oil is from your Head vent hoses and the ...   Mar 4 2009, 08:46 AM
Vacca Rabite   by the way, if it is bad rings... the only constr...   Mar 4 2009, 08:53 AM
904svo   Way off the deep end, but did you check the oil pr...   Mar 4 2009, 01:25 PM
jsayre914   Way off the deep end, but did you check the oil p...   Mar 4 2009, 01:50 PM
type47   Way off the deep end, but did you check the oil ...   Mar 4 2009, 02:35 PM
yeahmag   The switch would not pump oil in to the air cleane...   Mar 4 2009, 02:23 PM
jsayre914   I just finished the compression test..... drumroll...   Mar 17 2009, 01:04 PM
Dr Evil   Well, since the two on the samer side, 1 and 2, ar...   Mar 17 2009, 01:51 PM
jsayre914   Well, since the two on the samer side, 1 and 2, a...   Mar 17 2009, 02:41 PM
Drums66   The AAR valve you are using the 4th photo is comm...   Mar 17 2009, 02:45 PM
yeahmag   The combination of oil in the air cleaner and low ...   Mar 17 2009, 03:43 PM
Dr Evil   Ah ya, if you are getting oil in your filter you a...   Mar 17 2009, 03:56 PM
yeahmag   I would think it unwise to do just the 1-2 side. I...   Mar 17 2009, 04:00 PM
19 User(s) are reading this topic (19 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 22nd December 2024 - 06:56 PM
