my oil/ engine problems diagnosis ?, updated, Just did compression test today 3/17/09 |
jsayre914 |
Mar 3 2009, 04:52 PM
Speed Up !!! Group: Members Posts: 3,206 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
take a look guys, by the way I did get her home the other night, and i beat the snow.
Attached image(s) |
Jake Raby |
Mar 3 2009, 07:28 PM
Engine Surgeon Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
Bad rings can create blowby as they allow gases to fill the crankcase, forcing an oily mess from every orfice...
The same thing happens with bad exhaust valve guides as the exhaust gases pass between the stem of the valve and the valve guide, pressurizing the rocker box and then the crankcase.. |
jsayre914 |
Mar 3 2009, 09:24 PM
Bad rings can create blowby as they allow gases to fill the crankcase, forcing an oily mess from every orfice... The same thing happens with bad exhaust valve guides as the exhaust gases pass between the stem of the valve and the valve guide, pressurizing the rocker box and then the crankcase.. (IMG:style_emoticons/default/idea.gif) so does the engine still gotta come out if it is the valve guides? |
r_towle |
Mar 3 2009, 09:33 PM
Custom Member Group: Members Posts: 24,656 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Bad rings can create blowby as they allow gases to fill the crankcase, forcing an oily mess from every orfice... The same thing happens with bad exhaust valve guides as the exhaust gases pass between the stem of the valve and the valve guide, pressurizing the rocker box and then the crankcase.. (IMG:style_emoticons/default/idea.gif) so does the engine still gotta come out if it is the valve guides? Yup and it takes less than a hour to get it out. Rich |
Lo-Fi Version | Time is now: 22nd December 2024 - 06:59 PM |
