my oil/ engine problems diagnosis ?, updated, Just did compression test today 3/17/09 |
jsayre914 |
Mar 3 2009, 04:52 PM
Speed Up !!! Group: Members Posts: 3,206 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
take a look guys, by the way I did get her home the other night, and i beat the snow.
Attached image(s) |
championgt1 |
Mar 3 2009, 08:15 PM
Don't embarrass me Filmore! Group: Members Posts: 2,680 Joined: 3-January 07 From: Tacoma, Washington Member No.: 7,420 Region Association: Pacific Northwest |
How did your engine run before this mess? The stacked vacuum elbow being disconnected would have been a MAJOR vaccum leak. Is this your oil leak problem. No.
jsayre914 |
Mar 3 2009, 09:28 PM
How did your engine run before this mess? The stacked vacuum elbow being disconnected would have been a MAJOR vaccum leak. Is this your oil leak problem. No. the car ran absolutly great, even with the smoke... it is/ was fast. i used a piece of silicon inside the double stack, but im not so sure it was perfectly tight, and from what im learning there is quite a bit of pressure in my case. |
r_towle |
Mar 3 2009, 09:34 PM
Custom Member Group: Members Posts: 24,656 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
How did your engine run before this mess? The stacked vacuum elbow being disconnected would have been a MAJOR vaccum leak. Is this your oil leak problem. No. the car ran absolutly great, even with the smoke... it is/ was fast. i used a piece of silicon inside the double stack, but im not so sure it was perfectly tight, and from what im learning there is quite a bit of pressure in my case. From what I have experienced with lots of motors, not just type 4, is if you get smoke on the highway when you let off the gas pedal, its rings. Rich |
Lo-Fi Version | Time is now: 22nd December 2024 - 07:05 PM |
