iamchappy |
It all happens so fast! ![]() ![]() ![]() ![]() Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest ![]() ![]() |
I am at this time considering a turbo install on my 3.0 engine, I would be using the guts of a used bae turbo kit for the 911sc. I know that I will have to do a lot of fabricating and loose some useable storage space in the trunk. I have enough support from those who have had the turbo kit installed on there cars for 20 years, and have sorted all the little problems out.
I now have to justify the need for 300hp, when my car runs great as is, but lacks a little heart pounding thrill. I like the idea of turbocharging as it is all external, biggest hp gains without internal modifications, and I have the capabilites of fabricating the plumbling. Plus it can be done for less than a pair of carbs. Someone twist my arm, it's a turbo or it's a new paint job for the car. (IMG:style_emoticons/default/confused24.gif) Chappy |
Sammy |
. ![]() ![]() ![]() Group: Members Posts: 1,190 Joined: 21-January 03 From: Orange, Ca Member No.: 178 ![]() |
Hi guys. Thanks for the welcome.
i agree that using a cold start injector in the stock location might be a gamble, he's using an injector that's located in the turbo compressor discharge piping so it has time to atomize before going through the throttle body. it would only be injecting diring periods of boost so the air vewlocities should be adequate to prevent pooling and the air temps would also be high, aiding atomization. As long as all 6 cylinders get the same amount of additional fuel there isn't a problem. If the distribution of fuel is not even it could burn a piston. I... I mean my "friend" is planning to use a good air/fuel ratio meter to monitor things as he creeps up on the boost. The car already has a turbo whale tail on it so room for an intercooler shouldn't be a problem. 5 psi boost should be good for around 70 additional horsepower which is plenty, for at least a week or two until it gets boring. That's the problem with boost, too much is not enough. |
Lo-Fi Version | Time is now: 24th June 2024 - 07:40 AM |
