> my oil/ engine problems diagnosis ?, updated, Just did compression test today 3/17/09
jsayre914
post Mar 3 2009, 04:52 PM
Speed Up !!!
take a look guys, by the way I did get her home the other night, and i beat the snow.
904svo
post Mar 4 2009, 01:25 PM
904SVO
Way off the deep end, but did you check the oil pressure switch? if its loose
it will cause a problem of splashing oil around. It's located by the distributor.
jsayre914
post Mar 4 2009, 01:50 PM
Speed Up !!!
QUOTE(904svo @ Mar 4 2009, 02:25 PM) *
i dont have an oil pressure guage, do i still have the switch? if so could someone point it out to me in one of my pics. i will check it.
thanks
type47
post Mar 4 2009, 02:35 PM
Viermeister
QUOTE(jsayre914 @ Mar 4 2009, 12:50 PM) *
i do i still have the switch?
yes, it is factory installed. Look for the wire coming out of the cooling tin just beside and behind (toward the rear of the car) the distributor. The wire is green with red stripe if I recall.
jsayre914   my oil/ engine problems diagnosis ?   Mar 3 2009, 04:52 PM
jsayre914   more   Mar 3 2009, 04:54 PM
jsayre914   ...   Mar 3 2009, 04:56 PM
jsayre914   last ones   Mar 3 2009, 04:57 PM
jsayre914   Zach said he would loan me a compression tester, i...   Mar 3 2009, 04:58 PM
yeahmag   Been a while since I had FI on the car. Could you ...   Mar 3 2009, 06:51 PM
jsayre914   Could you tell if it was coming from one of the b...   Mar 3 2009, 09:22 PM
Jake Raby   Tons of blow by... Either the rings are shot or th...   Mar 3 2009, 06:54 PM
type47   Good thing a response I made didn't get posted...   Mar 3 2009, 07:09 PM
yeahmag   When combustion gases go flying past the rings the...   Mar 3 2009, 07:21 PM
Jake Raby   Bad rings can create blowby as they allow gases to...   Mar 3 2009, 07:28 PM
jsayre914   Bad rings can create blowby as they allow gases t...   Mar 3 2009, 09:24 PM
r_towle   Bad rings can create blowby as they allow gases ...   Mar 3 2009, 09:33 PM
Dr Evil   So, when are we going to rebuild your engine :) :i...   Mar 3 2009, 07:54 PM
wertygrog   My engine does the same thing when a hose falls of...   Mar 3 2009, 08:06 PM
Vacca Rabite   Hey Joe, I'm not in class this week. Next we...   Mar 3 2009, 08:10 PM
championgt1   How did your engine run before this mess? The stac...   Mar 3 2009, 08:15 PM
jsayre914   How did your engine run before this mess? The sta...   Mar 3 2009, 09:28 PM
r_towle   How did your engine run before this mess? The st...   Mar 3 2009, 09:34 PM
jsayre914   anyone know where this came from??   Mar 3 2009, 09:33 PM
r_towle   oh, the oil is from your Head vent hoses and the l...   Mar 3 2009, 09:34 PM
Vacca Rabite   oh, the oil is from your Head vent hoses and the ...   Mar 4 2009, 08:46 AM
Vacca Rabite   by the way, if it is bad rings... the only constr...   Mar 4 2009, 08:53 AM
904svo   Way off the deep end, but did you check the oil pr...   Mar 4 2009, 01:25 PM
jsayre914   Way off the deep end, but did you check the oil p...   Mar 4 2009, 01:50 PM
type47   Way off the deep end, but did you check the oil ...   Mar 4 2009, 02:35 PM
yeahmag   The switch would not pump oil in to the air cleane...   Mar 4 2009, 02:23 PM
jsayre914   I just finished the compression test..... drumroll...   Mar 17 2009, 01:04 PM
Dr Evil   Well, since the two on the samer side, 1 and 2, ar...   Mar 17 2009, 01:51 PM
jsayre914   Well, since the two on the samer side, 1 and 2, a...   Mar 17 2009, 02:41 PM
Drums66   The AAR valve you are using the 4th photo is comm...   Mar 17 2009, 02:45 PM
yeahmag   The combination of oil in the air cleaner and low ...   Mar 17 2009, 03:43 PM
Dr Evil   Ah ya, if you are getting oil in your filter you a...   Mar 17 2009, 03:56 PM
yeahmag   I would think it unwise to do just the 1-2 side. I...   Mar 17 2009, 04:00 PM
- Lo-Fi Version Time is now: 22nd December 2024 - 06:34 PM
