> suby hotrod motors, Probably cost equal to a really good porsche 6
charliew
post Feb 24 2009, 09:50 AM
http://forums.nasioc.com/forums/showthread.php?t=1699103
These motors are probably 15-20k once they reach the track. Just a offhand guess. As my son has spent 13k on a street motor with no tranny mods. Just motor, ported heads, bigger cams, 100mm bore, open source tuning with datalogging and utec piggyback, bigger injectors, bigger fuel pump, bigger oil pump, front mount ic, 8qt oil pan, true cold air intake and a 30r rotated turbo at 26 psi. Conservative tune about 425awhp. Also no water or alcohol injection yet.
DBCooper
post Mar 8 2009, 03:28 PM
14's in the 13's with ATTITUDE
Shift "down" to fifth? The STI engine I was talking about is in a 914, so no sixth gear and no "parasitic" awd power loss either. Excepting the aerodynamics the 914/STI would keep up just fine since each car has about 7 lbs/hp, but why on earth would I want to try him on at top speed, anyway? On I-35? In a 914? Wouldn't happen. My fun is more like Hwy 49 between Mariposa and Coulterville, where there isn't a straight more than a quarter mile long. I'm sure as hell not hearing a beep beep from any Corvette on that road.
Any kind of engine running high levels of boost will consume oil, and any OHC engine needs the belts, chains maintained. Nothing special about the Subaru in that respect, one way or the other, and at 100K miles it still beats adjusting valives. From the build quality it sounds like your son knows what he's doing, but every hot rod turbo motor I've ever been around has tempted the owner to turn up the boost until something eventually popped. But since the first post my point has been that when it's in a 914 you don't even have to hot-rod a Subaru engine to have the same lbs/hp as you get in that monster Z06. You can do that with a bone-stock STI motor and have all the fun you want. Except, as you correctly point out, at top speeds on public highways.
charliew   suby hotrod motors   Feb 24 2009, 09:50 AM
cobra94563   porsche motor w/ 400+hp is more... now..an SBC...   Feb 24 2009, 10:12 AM
Vacca Rabite   porsche motor w/ 400+hp is more... now..an SBC.....   Feb 24 2009, 10:45 AM
J P Stein   Great power.... then comes the age old hot rod que...   Feb 24 2009, 10:31 AM
pktzygt   Great power.... then comes the age old hot rod qu...   Feb 24 2009, 10:37 AM
WRX914   Well this is a loaded question... A hot rod suby ...   Feb 26 2009, 02:14 PM
fiid   Well this is a loaded question... <<chopped...   Feb 27 2009, 08:10 PM
WRX914   Forgot to mention.... Because the engine complet...   Feb 26 2009, 02:21 PM
SnailPerformance   Forgot to mention.... Because the engine comple...   Mar 5 2009, 05:07 PM
DBCooper   At what point do you consider a Porsche engine to ...   Feb 26 2009, 03:14 PM
iamchappy   I may need to rethink my engine, sell my 400hp tur...   Feb 26 2009, 03:32 PM
turboman808   Yeah the subaru motor is so freakin cheap. But da...   Feb 26 2009, 03:40 PM
Brett W   Hell a 250hp 2.0 flat six is well into the 30K ran...   Feb 26 2009, 03:52 PM
DBCooper   Hell a 250hp 2.0 flat six is well into the 30K ra...   Feb 27 2009, 05:40 AM
charliew   Any suby powered 914 should be easier to handle th...   Feb 26 2009, 04:20 PM
DBCooper   I may need to rethink my engine, sell my 400hp tu...   Feb 26 2009, 04:24 PM
charliew   I see no reason to buy a renegade kit. But I like ...   Feb 27 2009, 12:11 AM
plymouth37   Subie is cheaper hands down. I have about 3K into ...   Feb 27 2009, 01:59 AM
grantsfo   Subie is cheaper hands down. I have about 3K into...   Feb 27 2009, 03:27 PM
Brett W   Turbos are the best thing for street cars. NA mot...   Feb 27 2009, 02:28 PM
turboman808   Turbos are the best thing for street cars. NA mo...   Feb 27 2009, 02:55 PM
effutuo101   I may need to rethink my engine, sell my 400hp t...   Feb 27 2009, 03:30 PM
WRX914   You do not need a aftermarket ECU. You simply nee...   Feb 27 2009, 07:22 PM
charliew   A 2.0 wrx converted to a 2.5 shortblock is called ...   Mar 3 2009, 12:02 AM
WRX914   A 2.0 wrx converted to a 2.5 shortblock is called...   Mar 3 2009, 03:05 PM
r_towle   please explain a few things. $1850 buy a shor...   Mar 3 2009, 04:11 PM
DBCooper   please explain a few things. $1850 buy a sho...   Mar 3 2009, 05:25 PM
fiid   Is it possible, or has anyone done it, to put a c...   Mar 5 2009, 04:34 PM
brant   It always comes down to priorities. try going vint...   Mar 3 2009, 04:25 PM
DBCooper   It always comes down to priorities. try going vin...   Mar 3 2009, 05:29 PM
grantsfo   It always comes down to priorities. try going vin...   Mar 16 2009, 11:23 AM
charliew   I have seen a custom itb setup on a suby but it wa...   Mar 3 2009, 10:15 PM
SnailPerformance   I have seen a custom itb setup on a suby but it w...   Mar 5 2009, 05:17 PM
charliew   [quote name='charliew' post='1141041' date='Mar 3...   Mar 14 2009, 12:44 PM
DBCooper   [quote name='SnailPerformance' post='1141879' dat...   Mar 16 2009, 06:24 AM
DBCooper   Really though as wrx914 said a good 300 hp that d...   Mar 5 2009, 05:21 PM
WRX914   I stand corrected... Charlie is correct. I calle...   Mar 5 2009, 04:20 PM
charliew   DB think about this, you are running about 80 on 3...   Mar 8 2009, 10:53 AM
DBCooper   Shift "down" to fifth? The STI engine I...   Mar 8 2009, 03:28 PM
WRX914   Last year I ran a hopped up Camaro SS that sounded...   Mar 9 2009, 01:52 PM
SnailPerformance   ill run just about anything in my car.. 505 z06 su...   Mar 9 2009, 10:41 PM
charliew   I don't know what year gsx-r1000 you are playi...   Mar 11 2009, 01:32 PM
biosurfer1   Next time I'm in Vegas, I'm going to need ...   Mar 11 2009, 01:59 PM
DBCooper   No, it's not a Gixxer, but you and a friend ca...   Mar 11 2009, 06:20 PM
charliew   Only thing I found on a nasioc search on treefroga...   Mar 16 2009, 10:53 AM
DBCooper   Only thing I found on a nasioc search on treefrog...   Mar 17 2009, 06:25 AM
biosurfer1   Holy moly....$2100/HOUR?!?!?   Mar 16 2009, 12:31 PM
grantsfo   Holy moly....$2100/HOUR?!?!? Hey th...   Mar 16 2009, 12:52 PM
charliew   I also love the sound of a flat six at 7500 but I ...   Mar 17 2009, 10:25 AM
DBCooper   No, Charlie, wasn't referring to you, it was T...   Mar 17 2009, 01:37 PM
charliew   My third, a 58 vw, was a college car to replace th...   Mar 17 2009, 02:19 PM
- Lo-Fi Version Time is now: 31st October 2024 - 07:31 PM
