Wilhelm |
Member ![]() ![]() Group: Members Posts: 408 Joined: 7-September 07 From: Hooterville, OR Member No.: 8,088 Region Association: None ![]() |
So its time to quit making parts and start building my car. My true goal despite a bunch of design ideas is to have something I can drive, enjoy, use, and convince the wife to ride in, making it worth the all effort I'm putting into this. I've started with a 74 yellow CA car with fairly mild hell hole rust. The first step was to strip the car of everything, steal all the one-quart freezer bags from the kitchen and label and bag everything I could think of. I threw together a rotisserie out of a bunch of rusty scrap pipe I found in a field. I had the wheels kicking around for years from Harbor Freight. I built this so I could have an off road rotisserie and get the car outside to sandblast it. When all is said and done the sandblasting took about 10 hours with about half that time devoted to heating up the seam sealer with a mapp torch and scrapping it out with chisels and picks. I probably spent and equal time sandblasting remnants of seams sealer to the the time spent on the entire remainder of the car. One thing that really sped up the sandblasting was to pre-prep large areas with paint stripper; the paint would come off very easily. None of the stripping is fun. Sandblasting requires a respirator, hearing protection (horrifically loud) and eye protection. I initially was wearing a tyvek suit and still got dirty. It also was about 100 degrees out and it got pretty ripe in there. I spent the remainder of the time dressed like in these pictures and all was well and good till the air hose separated from the nozzle and blasted the back of my upper arm. Really friggin hurt and looked like road rash. For eye protection I used the hood shown, then tried a full face shield. What worked best however was using an old welding helmet with a clear lens. The clear lenses would last about 1-2 hours and only cost $.49 to replace compared to a few bucks for the hood and 15 bucks for a shield neither of which had a longer life than the $.49 lens for the welding helmet.
Design goals: Sheridan front, end narrow body 959 style rear fenders 916 rear bumper Carbon fiber look top Monowiper (yeah like rice-a-roni) Though the hood radiator vent (wbergtho-style) Front hinged hood Turbo twist style wheels (8" front, 10" rear) 911 front end 5 lug 928 rear hubs (see my build - 928 Hybrid trailing arm ) Tilt wheel, smaller diameter, thinking from a jetta Power steering Move the stereo to where the heater controls are Air Conditioning with simplified HVAC controls Coffee cup holders 930 transmission (already have) Engine- either 327 (already have the 327) versus an LS2 |
3d914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region ![]() |
Very nice work!
Who's engine bar and motor mounts are those - did you fab? I'm curious why you didn't use the stock engine mounting locations. I'm still undecided how to mount my V6. Keep up the good work. |
Wilhelm |
QUOTE That .25 inch makes the belt replacement doable... Hope to never have to change the belt. I got 132,000 miles out of the serpentine belt on the S10 Blazer. Does that make me lazy or frugal? Who's engine bar and motor mounts are those - did you fab? I'm curious why you didn't use the stock engine mounting locations. I made the engine bar out of a piece of 2" square tube, .18" wall thickness IIRC. The aluminum motor mounts are standard GM items (they call them "stands") and the black round pieces are standard corvette motor isolators. While fixing some mild hell hole rust I thought the original mounts (especially the right side) looked weak and didn't want to risk ripping them out with the new motor. Also wanted to reinforce the inside of the frame rails as they were pitted from years of battery acid raining down on them. To take the original mounts out, I drilled the spot welds, and gave a thin chisel a few wacks between the frame rail and the mount. They came out shockingly easy and if I kept them would have, at a minimum, re-welded them. |
Lo-Fi Version | Time is now: 29th April 2025 - 01:55 AM |
