my oil/ engine problems diagnosis ?, updated, Just did compression test today 3/17/09 |
jsayre914 |
Mar 3 2009, 04:52 PM
Speed Up !!! Group: Members Posts: 3,206 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
take a look guys, by the way I did get her home the other night, and i beat the snow.
Attached image(s) |
Dr Evil |
Mar 17 2009, 01:51 PM
Send me your transmission! Group: Members Posts: 23,034 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Well, since the two on the samer side, 1 and 2, are low I would consider that ther head may have a problem in seating, twisting, etc. Did you check the head nuts on that side for tq? Is there any reason you should have bad rings? Did you put a tsp of oil in the bad barrels and then recheck to see if that improved the numbers? = bad rings.
Just a few thoughts (IMG:style_emoticons/default/smile.gif) |
jsayre914 |
Mar 17 2009, 02:41 PM
Well, since the two on the samer side, 1 and 2, are low I would consider that ther head may have a problem in seating, twisting, etc. Did you check the head nuts on that side for tq? Is there any reason you should have bad rings? Did you put a tsp of oil in the bad barrels and then recheck to see if that improved the numbers? = bad rings. Just a few thoughts (IMG:style_emoticons/default/smile.gif) i have not tried that... i will try it later, grocery shopping first. i was thinking in my mind somthing was wrong there, do rings usually wear equal all around or does it seem very likley that 1 and two could wear much faster than 3 and four?? |
Lo-Fi Version | Time is now: 22nd December 2024 - 06:50 PM |
