KaptKaos |
Family ![]() ![]() ![]() ![]() Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest ![]() |
I've had a pair 3" strut housings in my garage at least 2 years now. I have the struts, hubs, calipers and caliper rebuild kits. I tried to do a search on the 3" spacing for the calipers and found a lot of stuff. All very interesting, some helpful, but not exactly what I was looking for.
I assume that my struts are pre-74. If I recall correctly, I can use my existing strut cartridge in them from my stock 914 front. How do I know if that's correct? What do I need to look for to determine that? Where can I find an exploded diagram of the 911 front end, so I can make sure I have all of the bits that I need? I have a ton more questions, but those will suffice to start. Thanks in advance for your help with this. |
KaptKaos |
So I blasted, primed and painted my struts. Here's the blurry evidence:
![]() ![]() I think all that I need are: Inner bearings Outer bearings Rotors pads ball joints & pins 2 x caliper bolts (caliper to strut) and to figure out how the hard lines need to connect to the calipers and my fronts are done!! (I think) |
Lo-Fi Version | Time is now: 26th June 2024 - 07:06 AM |
