JOE M |
Member ![]() ![]() Group: Members Posts: 293 Joined: 27-August 07 From: N.H Member No.: 8,042 Region Association: None ![]() |
http://cgi.ebay.com/ebaymotors/VW-BUS-Type...sQ5fAccessories
Attached is a link to ebay. These are the carbs im thinking about using for my 72 1.7 liter. Just curious if anyone has ever used these and if they are easy to tune. |
hi4head |
Member ![]() ![]() Group: Members Posts: 69 Joined: 4-April 06 From: Lexington, NC Member No.: 5,819 Region Association: None ![]() |
Hi Joe,
I put in a set that are probably similar last year. I got the Weber 34 ICT duals off ebay. (webercarbsdirect I think) Overall I am pleased, even with them on a 2 liter engine. I did have to do a little modification to the brackets holding the linkage bar and air filters, but not a major deal. You may also need to change the jets. (At least I needed to go larger.) I've read some negative comments about the Weber guys, but my experience with them was very positive. You'll need to make some kind of bracket for the throttle cable and you'll need a low pressure fuel pump. You'll also probably want to get a guage to balance the airflow on the two carbs, a larger return spring to help with the linkage, and there probably are other things that I simply don't remember. Good luck and have fun. Chris |
Lo-Fi Version | Time is now: 18th June 2024 - 07:31 AM |
