76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,519 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
(IMG:style_emoticons/default/confused24.gif) How do you access the nut to remove the dist? Sacrifice a wrench? Buy set of crows feet?
tradisrad |
Senior Member ![]() ![]() ![]() Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California ![]() |
Loosen the dizzy then rotate it so you can get to the 13mm nut that is holding the clamp then pull it out with the clamp. It can also be removed w/o removing the clamp but the o-ring can hang up on the clamp
Lo-Fi Version | Time is now: 27th June 2024 - 09:03 PM |
