> Fuel tank lines, searched but not sure...
wobbletop
post Apr 19 2009, 01:08 PM
Hi all,
Just really starting to get to know my 914. Car has always smelled of gas and once my passenger complained of gas at her feet. The previous owner had removed the expansion tank and charcoal canister when he did the 3.0L swap which came with carbs.
I tried to do some debugging today to figure out where the gas was coming from. Only happens (or is noticed) with a full tank. I attached some small bags to the end of the hose that used to attached to the expansion tank, and to the large tube that comes off the "scupper" around the tank filler.
I noticed don't have the large hose that is in this picture that runs off the scupper. I could not find any diagrams for this line anywhere.
(IMG:http://www.914world.com/bbs2/uploads/post-378-1183570635.jpg)
Where does the other end of that hose go?
Anyway... after a short drive with some quick side to side transitions (like warming tires) I stopped and noticed that BOTH bags had gas in them.
Is it normal for the evaporate line to have gas in it?
Where could the gas from the big tube be coming from? The gas cap SEEMS to have a good seal. Also, there doesn't appear to be any gas underneath the scupper. It doesn't appear to be leaking.
I also found this diagram but it doesn't show the large tube on the other side.
(IMG:http://www.914world.com/bbs2/uploads/post-104-1217472597.jpg)
The two hoses that run the length of the car are still in the front trunk, but I'm not sure if they attach to anything in the engine compartment.
Thanks for you help.
davesprinkle
post Apr 19 2009, 06:40 PM
Gas smell in the cockpit can come from a number of places, some of them listed by previous posters:
1. The rubber gasket under the gas cap is probably hard. This isn't available anymore, but I was able to cut a replacement out of 1/8" rubber sheet, available from the FLAPS. Works great.
2. Any slight leak from the fittings at the bottom of the tank will generate a fuel smell. Even if the leak isn't large enough to wet the ground, the vapors will make their way into the passenger compartment. These fittings are sealed with small ring gaskets, no longer available. AA will sell replacements, but they're the wrong size. Again, I cut replacements out of gasket material, with good success.
3. Pay attention to the overflow tank lines, as mentioned.
4. Many times, the tank will rust where it sits on carpet pads placed by the factory between the tank and the inner fender of the car.
5. This one is from Chris Foley -- a sheetmetal screw was run through the passenger compartment firewall and it punctured the fuel tank on the other side. Moral -- don't mount your amplifier to the firewall using sheetmetal screws. (If your passenger is getting fuel on her feet, this is one way it could happen.)
- Lo-Fi Version Time is now: 21st December 2024 - 11:15 PM
