> Over Heating Starter, won't start after a commute
yellow914
post Apr 22 2009, 05:51 PM
Starter is apparently over heating during my commute (which it didn't do for the past year)
(1).What's the cause? (yes I know heat...why I odda (IMG:style_emoticons/default/chair.gif) )
(2). Is the only cure a new starter?......or...?
(3). I also have an interesting idle also...the "warmer" the car the lower the idle?
Help Por-favor : (IMG:style_emoticons/default/driving.gif)
r_towle
post Apr 22 2009, 06:30 PM
Custom Member
The main problem is that your electrical connections are dirty.
Clean the grounds, battery to body, and the tranny ground strap.
Clean the positive lead at the battery and at the starter.
High heat creates more resistance in electrical circuits.
Rich
yellow914   Over Heating Starter   Apr 22 2009, 05:51 PM
Jeffs9146   Ahhhhh the infamous Hot Starter Not Worky problem ...   Apr 22 2009, 06:05 PM
914Sixer   Options: High torque starter 72-up 911 starter Sta...   Apr 22 2009, 06:07 PM
r_towle   The main problem is that your electrical connectio...   Apr 22 2009, 06:30 PM
charliew   Sounds like the aircooled vw starter too far from ...   Apr 22 2009, 07:02 PM
r_towle   Please dont add the relay, its just masking the is...   Apr 22 2009, 07:13 PM
DBCooper   Please dont add the relay, its just masking the i...   Apr 23 2009, 05:40 AM
Jeffs9146   I have delt with this many times and it comes do...   Apr 22 2009, 07:24 PM
charliew   On old chevs you could disassemble the solenoid an...   Apr 23 2009, 11:12 AM
SUNAB914   Not much description of your problem. How are you ...   Apr 23 2009, 12:54 PM
charliew   The 914 wiring is designed exactly like the bug th...   Apr 23 2009, 10:35 PM
MBowman325   Failing all of the above, you could just carry a s...   Apr 24 2009, 09:03 AM
DBCooper   Maybe a quibble but I don't know why you'd...   Apr 24 2009, 09:20 AM
r_towle   I wish I could somehow type the sound you make whe...   Apr 24 2009, 09:53 AM
Cupomeat   Well, regarding the relay masking, etc. I had this...   Apr 24 2009, 10:01 AM
swl   I'm with Rich. If a relay 'fixes' the...   Apr 24 2009, 08:40 PM
smooth_eddy   I had the same problems. The best solution (in my...   Apr 24 2009, 08:54 PM
klink   Funny story. I had bought a '72 new off the s...   Apr 24 2009, 09:08 PM
swl   I'd have to say stupid stories like these a...   Apr 25 2009, 06:06 AM
porsha916   1 Go to Walmart buy a #6 wire about six feet long ...   Apr 24 2009, 09:16 PM
Cupomeat   No doubt that the resistance of the circuit and su...   Apr 24 2009, 09:19 PM
jaxdream   SWL , that was a very good explanation of the circ...   Apr 25 2009, 08:35 AM
Drums66   1. new starter 2. new solenoid 3. hot start kit 4....   Apr 26 2009, 02:18 PM
MBowman325   While it was touched on, it wasn't stated dire...   Apr 26 2009, 03:38 PM
yellow914   First: Thank you all for your help this site is in...   Apr 28 2009, 03:57 PM
Tom   Well, this issue sure comes up a lot. I know that ...   May 1 2009, 01:40 PM
- Lo-Fi Version Time is now: 7th January 2025 - 10:13 PM
