Over Heating Starter, won't start after a commute |
yellow914 |
Apr 22 2009, 05:51 PM
Member Group: Members Posts: 183 Joined: 28-March 08 From: San Jose, CA Member No.: 8,861 Region Association: Northern California |
Starter is apparently over heating during my commute (which it didn't do for the past year)
(1).What's the cause? (yes I know heat...why I odda (IMG:style_emoticons/default/chair.gif) ) (2). Is the only cure a new starter?......or...? (3). I also have an interesting idle also...the "warmer" the car the lower the idle? Help Por-favor : (IMG:style_emoticons/default/driving.gif) |
r_towle |
Apr 22 2009, 07:13 PM
Custom Member Group: Members Posts: 24,683 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Please dont add the relay, its just masking the issue.
The car is 35 years old...sometimes you need to clean the corrosion on the battery terminals and the main cables...thats all...its simple. Rich |
DBCooper |
Apr 23 2009, 05:40 AM
14's in the 13's with ATTITUDE Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California |
Please dont add the relay, its just masking the issue. Sure, clean the terminals, do the simplest thing first, but the way it was was done by the factory is an old-fashioned and lousy way to wire a car. Once you put in a Ford solenoid there is no more problem from heat, so if the starter begins to fail really a bad starter. |
Lo-Fi Version | Time is now: 7th January 2025 - 10:22 PM |
