> Over Heating Starter, won't start after a commute
yellow914
post Apr 22 2009, 05:51 PM
Starter is apparently over heating during my commute (which it didn't do for the past year)
(1).What's the cause? (yes I know heat...why I odda (IMG:style_emoticons/default/chair.gif) )
(2). Is the only cure a new starter?......or...?
(3). I also have an interesting idle also...the "warmer" the car the lower the idle?
Help Por-favor : (IMG:style_emoticons/default/driving.gif)
porsha916
post Apr 24 2009, 09:16 PM
1 Go to Walmart buy a #6 wire about six feet long (about $3.00) attach to the body ground where the battery is attach, the other end attach to the starter bolt that holds the stater on, clean before attaching.
2. Put a cork gasket between starter the engine, run a heavy gauge to both sides, this should cut heat transfer.
Take Care
Bill
yellow914   Over Heating Starter   Apr 22 2009, 05:51 PM
Jeffs9146   Ahhhhh the infamous Hot Starter Not Worky problem ...   Apr 22 2009, 06:05 PM
914Sixer   Options: High torque starter 72-up 911 starter Sta...   Apr 22 2009, 06:07 PM
r_towle   The main problem is that your electrical connectio...   Apr 22 2009, 06:30 PM
charliew   Sounds like the aircooled vw starter too far from ...   Apr 22 2009, 07:02 PM
r_towle   Please dont add the relay, its just masking the is...   Apr 22 2009, 07:13 PM
DBCooper   Please dont add the relay, its just masking the i...   Apr 23 2009, 05:40 AM
Jeffs9146   I have delt with this many times and it comes do...   Apr 22 2009, 07:24 PM
charliew   On old chevs you could disassemble the solenoid an...   Apr 23 2009, 11:12 AM
SUNAB914   Not much description of your problem. How are you ...   Apr 23 2009, 12:54 PM
charliew   The 914 wiring is designed exactly like the bug th...   Apr 23 2009, 10:35 PM
MBowman325   Failing all of the above, you could just carry a s...   Apr 24 2009, 09:03 AM
DBCooper   Maybe a quibble but I don't know why you'd...   Apr 24 2009, 09:20 AM
r_towle   I wish I could somehow type the sound you make whe...   Apr 24 2009, 09:53 AM
Cupomeat   Well, regarding the relay masking, etc. I had this...   Apr 24 2009, 10:01 AM
swl   I'm with Rich. If a relay 'fixes' the...   Apr 24 2009, 08:40 PM
smooth_eddy   I had the same problems. The best solution (in my...   Apr 24 2009, 08:54 PM
klink   Funny story. I had bought a '72 new off the s...   Apr 24 2009, 09:08 PM
swl   I'd have to say stupid stories like these a...   Apr 25 2009, 06:06 AM
porsha916   1 Go to Walmart buy a #6 wire about six feet long ...   Apr 24 2009, 09:16 PM
Cupomeat   No doubt that the resistance of the circuit and su...   Apr 24 2009, 09:19 PM
jaxdream   SWL , that was a very good explanation of the circ...   Apr 25 2009, 08:35 AM
Drums66   1. new starter 2. new solenoid 3. hot start kit 4....   Apr 26 2009, 02:18 PM
MBowman325   While it was touched on, it wasn't stated dire...   Apr 26 2009, 03:38 PM
yellow914   First: Thank you all for your help this site is in...   Apr 28 2009, 03:57 PM
Tom   Well, this issue sure comes up a lot. I know that ...   May 1 2009, 01:40 PM
- Lo-Fi Version Time is now: 7th January 2025 - 10:15 PM
