> 1.8 w ljet takes a lot of cranking to start, need feedback please
jsayre914
post Apr 26 2009, 01:48 PM
Speed Up !!!
with my 2.0 d-jet i would turn the key on and off a few times befor i would crank it, and it started right up... cold or hot. It also had the fuel pump hooked directly to the postive on the coil.
Now with the 1.8, when i turn the key on and off a few times i hear nothing. Then when i turn to crank it, i hear the fuel pump running, but it cvranks and cranks and then starts.
This morning i thought i was killing my starter and battery. I dont want to fry the ignition switch.
what do you think might be the problem, i am almost willing to hook up my fuel pump incorrectly to see if it starts right up like it used to.
The starter is less than a year old, and the condition of the ljet, needs refreshing. car runs with a little hesitation, i think from the throttle switch is worn. (bucking) and i have no power in 5th gear at all. i hear a very low hollw sound when i push the gas down at this speed. When i ease up on the pedal sometimes i can pick up a little speed. (is that lack of fuel?) plenty of power in 4th gear.
cheers
- Lo-Fi Version Time is now: 26th December 2024 - 07:49 PM
