Rear coilovers - washer/bumper setup, Does this look about right? |
Qarl |
Jan 30 2004, 08:40 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
I have the aluminum had (which sits in the spring).
On top of the shaft is a large flat washer, that only goes to a certain point, because the shock shaft diameter increases) On top of the large flat washer are the two rubber pieces with the internally threaded sleeve. On top of that is a smaller washer And then the locking nut. Will this work? (and I'll ziptie the spring to the hat too!) Attached image(s) |
DNHunt |
Jan 30 2004, 09:28 PM
914 Wizard? No way. I got too much to learn. Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
Karl
I can't see a thing. Did Andy help you take the pictures? Not sure I could help you if I could see. Maybe I shouldn't have celebrated fixing my exhaust leak. I think I'll take a look at it in the morning Dave |
Lo-Fi Version | Time is now: 25th June 2024 - 08:27 PM |
