Tires spinning on the rim ..., How much of a problem is this? |
SirAndy |
Apr 27 2009, 10:55 AM
Resident German Group: Admin Posts: 41,961 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I always mark the race tires right where the valve stem is so i don't have to look for the stem when i'm in a hurry.
We put a new set of tires on the 911 one week ago at Tunderhill and this weekend i noticed that the markings had moved several inches in relationship to the valve stem. So i marked the stem location again with a small dot and sure enough, after the first run session, the tires had moved again by several inches. This only seems to happen in the rear, i'm guessing under hard acceleration when the tires are cold (first session in the morning). Is this something that needs to be addressed or should i not worry about it? (IMG:style_emoticons/default/confused24.gif) Andy |
Brett W |
Apr 27 2009, 02:54 PM
Advanced Member Group: Members Posts: 2,858 Joined: 17-September 03 From: huntsville, al Member No.: 1,169 Region Association: None |
Is this on your street car or just an autox car? If dedicated autox car, I wouldn't even bother balancing them, much less worry about the slipping.
SirAndy |
Apr 27 2009, 10:30 PM
Is this on your street car or just an autox car? If dedicated autox car, I wouldn't even bother balancing them, much less worry about the slipping. Toyo Spec 911 race car, GTS class with PRC, SP911 class with PCA. No Street, no AX, just *big* track ... 3.0L with aftermarket FI. About ~270 HP at the rear wheels. 245 x 16 Toyo RA1 tires in the rear. (IMG:style_emoticons/default/shades.gif) Andy PS: I have no idea what lube or how much of it they used when they mounted the tires. I didn't stick around to watch them put them on, just picked 'em up later ... Attached thumbnail(s) |
anderssj |
Apr 28 2009, 09:10 AM
Dog is my copilot... Group: Members Posts: 1,716 Joined: 28-January 03 From: VA Member No.: 207 Region Association: MidAtlantic Region |
No Street, no AX, just *big* track ... 3.0L with aftermarket FI. About ~270 HP at the rear wheels. 245 x 16 Toyo RA1 tires in the rear. (IMG:style_emoticons/default/shades.gif) Andy PS: I have no idea what lube or how much of it they used when they mounted the tires. I didn't stick around to watch them put them on, just picked 'em up later ... Andy, I copied this from a Michelin Technical Bulletin: LUBRICANT FOR MICHELIN TRUCK TIRES (Revised 15 MAY 2006): "It is essential that only an approved tire mounting lubricant be used when mounting Michelin® Truck Tires. Vegetable oil soaps or animal oil soaps, in solution, are the preferred materials for use as bead lubricants. Never use antifreeze, gasoline, ether, silicones, or any petroleum based lubricants. Never dilute lubricants beyond that recommended by the manufacturer since this may have a harmful effect on the tire and wheel/rim. The lubricant serves three purposes: • Helps minimize the possibility of damage to the tire beads from the wheel or mounting tools. • Helps ease the introduction of the tire onto the wheel/rim by lubricating all contacting surfaces. • Assists in proper bead seating and helps to prevent eccentric mounting. It is important that the tire lubricant be kept clean and free of dirt, sand, metal shavings or other hard particles. Tubeless Tires: We recommend lubricating both beads on the tire and the entire wheel surface from flange to flange. The tire must be mounted and inflated before the lubricant dries. Avoid using excessive amounts of lubricants. (Puddling of the lubricant inside the tire is considered excessive.)" (IMG:style_emoticons/default/blink.gif) I've had good luck using 3 or 4 oz of "Murphy's Oil Soap" in a quart (32oz) of warm water--and usually allow a day--or two--for everything to dry before putting any high braking/acceleration forces on the tires (as always, YMMV). Hope this helps! |
Lo-Fi Version | Time is now: 6th January 2025 - 07:11 PM |
