Back in a 914 - and have one question now- more to follow I'm sure |
Jona Gold |
Apr 27 2009, 09:37 AM
The Righteous are as Bold as a Lion Group: Members Posts: 45 Joined: 20-March 06 From: Central Minnesota Member No.: 5,745 Region Association: Northstar Region |
Hi out there-
It's been just over two years since I owned a 914 and my wife and I just bought another this weekend. It's a 1970 1.7L and seems to be reasonably stock. I have an issue I'd like to work out sooner rather than later and hoped someone could help. I searched the forums first- didn't find what I was looking for and so here goes: The fifth gear on this '70 pops out - especially under load (upon giving it gas to go faster). I recall my '73 having a similar issue- but it was with a different gear and it was the side shift tranny - not the tail shifter that's in this early car. I had a 71 tail shifter as well- never had an issue with that one. I plan to commute in this car this summer and my commute is 40 miles one way- so I'll use 5th gear a lot! I'm hoping to NOT have to hold the shifter in 5th all the way to work! Any ideas or suggestions on how to remedy this issue would be great. Of course being a 914er I'm budget minded- don't mind the sweat and elbow grease methods though! So what's the least expensive but SAFEST way to resolve the issue? Should I check linkage first? Any trick to that? I've not played with tail-shift linkage yet. Thanks! |
Dr Evil |
Apr 28 2009, 10:55 AM
Send me your transmission! Group: Members Posts: 23,032 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Like I said, not a naturally occuring problem. I commonly, with the permission of the owner, will swap 2/3 and 4/5 sliders as the 4/5 tend to be in excellent shape. To swap a 2/3 in shitty shape into the 4/5 slot would yield bad results instantly. I would be suspect of any work on this box. Did it just start with htis problem or has it always been this way?
You still need to check the external stuff or you may end up in the same spot. |
Lo-Fi Version | Time is now: 31st October 2024 - 07:27 PM |
