Burning Question, Charged Battery and Melted Fuse |
EdwardBlume |
Apr 30 2009, 07:54 PM
914 Wizard Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California |
I picked up a car with front end damage. I charged up the battery to full, got a little spark when I connected the ground (second). The car cranked just fine, but then I could smell smoke inside. Fearing an electrical fire, I disconnected the battery. Coming back inside, I looked at the fuse box and saw that the 4 left fuses were gone, and the single far right fuse was "shorter". Upon touching it, it was hot and melting.
Did this happen because the 4 right fuses were out? Can I just replace the 5 fuses and be OK? Or do I have a bigger problem? Thanks, R |
EdwardBlume |
Apr 30 2009, 09:48 PM
I picked up a car with front end damage. I charged up the battery to full, got a little spark when I connected the ground (second). The car cranked just fine, but then I could smell smoke inside. Fearing an electrical fire, I disconnected the battery. Coming back inside, I looked at the fuse box and saw that the 4 left fuses were gone, and the single far right fuse was "shorter". Upon touching it, it was hot and melting. Did this happen because the 4 right fuses were out? Can I just replace the 5 fuses and be OK? Or do I have a bigger problem? Thanks, R Got it. The 12 slot is the 25amp headlight motor, the smooshed part of the car. If I disconnect the grounds to the headlights, I should be OK right? THanks, R |
Lo-Fi Version | Time is now: 26th September 2024 - 05:19 PM |
