tomeric914 |
One Lap of America in a 914! ![]() ![]() ![]() Group: Members Posts: 1,259 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States ![]() ![]() |
ok, so I converted my 914 rear brakes to vented disc with 911 M calipers and internal drum parking brakes. Brakes work great but the pedal travel is longer than it should be. Went to rebleed everything and found that one of the rear calipers had a pad to disc clearance of .010" which probably explains the travel. Also verified that the pistons were working and not hanging up.
I've got a rebuilt proportioning valve from PMB that is working correctly. Running an ATE 19mm MC (bought a new one thinking it had the 17mm). No bubbles in the system using ATE SuperBlue brake fluid. I've never seen a caliper piston release that far just on one side. Anyone have any ideas? This is frustrating! |
jaxdream |
Senior Member ![]() ![]() ![]() Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States ![]() |
Do you have the 5mm spacer between the caliper and the mounting bracket on the trailing arm ?? Are you sure they are M's ?? 84 on up 911's used a rear caliper the same size except the middle spacers were 4mm wider for 24mm wide rotor versus the earlier 20mm wide rotor the M's used. Some one else probably knows what else to check. Good luck. (IMG:style_emoticons/default/confused24.gif)
Jaxdream |
Wes V |
Member ![]() ![]() Group: Members Posts: 482 Joined: 11-October 07 From: Los angeles Member No.: 8,211 ![]() |
Is it returning that far, right after bleeding, or after a drive.
As I understand it, the 911 rear M's had an "anti-knock back" mechanism within the piston that was to prevent this, if there was excessive wobble of the rotor (due to the fact that you can't snug up the one piece rear bearing). This would only effect you if the run-out (or wobble) of the rear rotor is excessive. Wes |
Lo-Fi Version | Time is now: 25th June 2024 - 07:47 PM |
