How do you adjust idle on 1975 1.8L l-jetronic |
steveneashcraft |
May 16 2009, 05:21 PM
Newbie Group: Members Posts: 6 Joined: 30-April 09 From: Arizona Member No.: 10,317 Region Association: None |
Assuming that everything is right. Where is the idle adjustment on a 1975 Porsche 914 with a 1.8L engine with l-jetronic. Car is absolutely stock.
steveneashcraft |
May 17 2009, 08:39 AM
Thanks for the quick reply. I'm still confused about how to set the idle on a 1.8 L-Jetronic. If that screw allowed more air to bypass the butterfly valve or moved the butterfly valve then I'd understand how it could adjust the idle. Does it do either or is it just a plug on the 1.8L throttle body with L-Jetronic since the same throttle body is probably used on other 914 intake systems? Ideas?
Lo-Fi Version | Time is now: 22nd December 2024 - 06:40 PM |
