Fuel Pump Hot Wired, Clogged??? Still here the buzz?? |
thompson-mfr |
May 22 2009, 10:43 AM
Thompson, Ryan Group: Members Posts: 198 Joined: 30-September 08 From: Silverton, OR Member No.: 9,598 Region Association: Pacific Northwest |
I have been trouble shooting my fuel system and hot wired the fuel pump.
I essentially bench tested it in the front trunk with the two output lines going to a gas can and the supply line still hooked up. I just changed the filter and checked to make sure there was flow after the filter and there was. I applied 12v to the pump correctly with + and - correct (HM!), but no gas through the pump. Can I blow compressed air gently through the pump to see if there are any obstructions???? |
montoya 73 2.0 |
May 22 2009, 11:10 AM
Lack of consideration to others, and Selfish! Group: Members Posts: 1,791 Joined: 27-October 04 From: Paso Robles, Ca. Member No.: 3,016 Region Association: Central California |
(IMG:style_emoticons/default/WTF.gif) My 73 2.0 is doing the same thing. I hear the stock pump click on and then it clicks off, but no gas. (IMG:style_emoticons/default/confused24.gif)
Anyone have a line on some stock fuel pumps? I have been trouble shooting my fuel system and hot wired the fuel pump. I essentially bench tested it in the front trunk with the two output lines going to a gas can and the supply line still hooked up. I just changed the filter and checked to make sure there was flow after the filter and there was. I applied 12v to the pump correctly with + and - correct (HM!), but no gas through the pump. Can I blow compressed air gently through the pump to see if there are any obstructions???? |
thompson-mfr |
May 22 2009, 11:15 AM
(IMG:style_emoticons/default/WTF.gif) My 73 2.0 is doing the same thing. I hear the stock pump click on and then it clicks off, but no gas. (IMG:style_emoticons/default/confused24.gif) Anyone have a line on some stock fuel pumps? I have been trouble shooting my fuel system and hot wired the fuel pump. I essentially bench tested it in the front trunk with the two output lines going to a gas can and the supply line still hooked up. I just changed the filter and checked to make sure there was flow after the filter and there was. I applied 12v to the pump correctly with + and - correct (HM!), but no gas through the pump. Can I blow compressed air gently through the pump to see if there are any obstructions???? I bought my car from an old man and he had 3-4 that he gave me. You can call me if you want to get one of them. I will PM you. |
Lo-Fi Version | Time is now: 25th June 2024 - 05:11 PM |
