thompson-mfr |
Thompson, Ryan ![]() ![]() Group: Members Posts: 198 Joined: 30-September 08 From: Silverton, OR Member No.: 9,598 Region Association: Pacific Northwest ![]() |
I have been trouble shooting my fuel system and hot wired the fuel pump.
I essentially bench tested it in the front trunk with the two output lines going to a gas can and the supply line still hooked up. I just changed the filter and checked to make sure there was flow after the filter and there was. I applied 12v to the pump correctly with + and - correct (HM!), but no gas through the pump. Can I blow compressed air gently through the pump to see if there are any obstructions???? |
Elliot Cannon |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None ![]() ![]() ![]() |
High pressure FI or low pressure carbs? How many miles on the pump? Iether way, if it's not running (you should be able to clearly hear it) it's probably toast. (No offense Melba) (IMG:style_emoticons/default/wub.gif)
Lo-Fi Version | Time is now: 25th June 2024 - 05:31 PM |
