Leaking brake fluid, but from what? |
mpoffers |
May 22 2009, 10:43 PM
Member Group: Members Posts: 52 Joined: 15-September 08 From: Portland, OR Member No.: 9,551 Region Association: Pacific Northwest |
Finally got my 75 914 through Oregon DEQ and took my first real drive on some twisties. Just a quick loop out Skyline, down Mcnamee and back in on US30. It kicked ass.
Now I've got a pretty good pool of brake fluid dripping from near the passenger rear jack donut. Any guess on what blew up? I assume that it has something to do with some sort of rear T valve or something, but I have yet to get it on jackstands and take a look. If I can finish my bathroom remodel I'll get to take a look at it tomorrow morning. In the meantime, anyone want to take a guess at what I broke? Mike |
GeorgeRud |
May 22 2009, 10:59 PM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
The passenger rear brake line has a fitting between the metal line and the flexible rear brake line right in that area. If you have the metal braided brake lines, I would consider replacing them with the original type. They do fail after many years, and when they go, it's a sudden crack and brake fluid leak.
SirAndy |
May 22 2009, 11:06 PM
Resident German Group: Admin Posts: 41,815 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
The passenger rear brake line has a fitting between the metal line and the flexible rear brake line right in that area. If you have the metal braided brake lines, I would consider replacing them with the original type. They do fail after many years, and when they go, it's a sudden crack and brake fluid leak. (IMG:style_emoticons/default/agree.gif) The valve is on the drivers side on the lower firewall, so that's not it. Probably just a old worn out brake-line. Get some good OEM rubber lines and replace on all 4 corners. If one went bad, chances are, the other three don't look much better ... (IMG:style_emoticons/default/shades.gif) Andy |
mpoffers |
May 22 2009, 11:54 PM
The passenger rear brake line has a fitting between the metal line and the flexible rear brake line right in that area. If you have the metal braided brake lines, I would consider replacing them with the original type. They do fail after many years, and when they go, it's a sudden crack and brake fluid leak. (IMG:style_emoticons/default/agree.gif) The valve is on the drivers side on the lower firewall, so that's not it. Probably just a old worn out brake-line. Get some good OEM rubber lines and replace on all 4 corners. If one went bad, chances are, the other three don't look much better ... (IMG:style_emoticons/default/shades.gif) Andy Sounds like a good guess to me. I'll crawl under there tomorrow and see what I find. Replacing them all is, of course, a good idea. I have no idea how old the current lines are but I did need to rebuild the front calipers as the driver's side was stuck. That probably should have clued me in to re-furbing the whole system. Now that I know how much fun this car is to drive, I'll gladly through $60 at new brake lines. |
Lo-Fi Version | Time is now: 26th September 2024 - 11:44 AM |
