Strut coolant fluid?, what goes in |
jaxdream |
May 23 2009, 11:37 AM
Senior Member Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States |
I scored a set of 89 Carrea Boge struts to use my 914 inserts in.Pulled the 89 insert out looks like the valving set up used in motorcycle front forks (IMG:style_emoticons/default/WTF.gif) Anyway my 914 insert fits in ok just got to come up with centering rings for the insert , my question is do I fill with some kind of coolant , the Paragon article states either oil or antifrezze , or is this not neccesary for a sealed insert unit ??
Strut prt # 911.341.041/042.04 Do fill with fluid or not ?? (IMG:style_emoticons/default/confused24.gif) Jaxdream |
cwpeden |
May 23 2009, 03:34 PM
Great White North, huh? Group: Members Posts: 916 Joined: 20-August 06 From: Victoria BC Member No.: 6,693 Region Association: Canada |
Unless your racing, how much heat do you think your shocks will generate?
ArtechnikA |
May 23 2009, 06:01 PM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
Unless your racing, how much heat do you think your shocks will generate? It doesn't really matter... A quart of ATF will do both struts (with a bunch left over) and it's an easy "no downside" As Long As. Consider that what are commonly called 'shock absorbers' aren't (the springs absorb the shocks...) they are really spring dampers and the axial forces can easily be 3X the spring rate. They get hot, and the heat serves no purpose. QUOTE so thats why the negative term "fish oil" is used with cheap shocks Have you ever pulled open an original-to-the-car Boge strut - the ones with *no insert* ? Yes, folks, as delivered from the factory, the pistons ran directly in the strut tube (this was true for /6's, I donno about /4's). I've done that job twice and the Boge hydraulic fluid is as horribly nasty smelling as anything you'd never hope to come across. Dead fish is a good approximation... |
Lo-Fi Version | Time is now: 24th June 2024 - 11:20 PM |
