I cant be the only one driving around, without 1st and reverse |
jsayre914 |
May 24 2009, 11:07 AM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
I already know i need some clutch adjustment, but what a pain in the ass. Last year i was driving around with no clutch at all. (from york pa to baltimore and back again) now i got the clutch working ... thank god. Its alot easier to drive these cars with a clutch. (IMG:style_emoticons/default/biggrin.gif)
now the problem is i got all the gears apon startup, but after about 15min of driving first and reverse are no more. I cant even try to get it in without a terrible sound that says NO WAY MAN. so i start out in second and dont even try reverse. But when the car cools off again their back. (IMG:style_emoticons/default/WTF.gif) I already talked to evil, he will help me out to rebuid my tranny, but i dont have $$$ for that yet. Any tricks you guys have for me, am i the only one with temporary gearing. (IMG:style_emoticons/default/confused24.gif) |
SirAndy |
May 24 2009, 12:24 PM
Resident German Group: Admin Posts: 41,696 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
And make sure both cone screws are tight. All your adjustments will be useless if they're lose ...
(IMG:style_emoticons/default/shades.gif) Andy |
zymurgist |
May 24 2009, 01:22 PM
"Ace" Mechanic Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None |
And make sure both cone screws are tight. All your adjustments will be useless if they're lose ... (IMG:style_emoticons/default/shades.gif) Andy (IMG:style_emoticons/default/agree.gif) When I had Babydoll, I thought the transmission broke when I went out for a drive. Couldn't get her into 1st gear, so I limped home starting off in 2nd (fortunately there were only a few stops). I panicked because I thought I had broken something expensive, especially since it was my job to fix Babydoll in the first place. Turned out to be a loose cone screw at the transmission end. (IMG:style_emoticons/default/driving.gif) |
jsayre914 |
May 24 2009, 01:25 PM
And make sure both cone screws are tight. All your adjustments will be useless if they're lose ... (IMG:style_emoticons/default/shades.gif) Andy (IMG:style_emoticons/default/agree.gif) When I had Babydoll, I thought the transmission broke when I went out for a drive. Couldn't get her into 1st gear, so I limped home starting off in 2nd (fortunately there were only a few stops). I panicked because I thought I had broken something expensive, especially since it was my job to fix Babydoll in the first place. Turned out to be a loose cone screw at the transmission end. (IMG:style_emoticons/default/driving.gif) when you say "couldnt get into first" did you mean it was grinding like crazy as if no clutch or you meant 1st was missing as in the gear was not there anymore?? |
Lo-Fi Version | Time is now: 22nd June 2024 - 04:46 AM |
