I cant be the only one driving around, without 1st and reverse |
jsayre914 |
May 24 2009, 11:07 AM
Speed Up !!! Group: Members Posts: 3,199 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
I already know i need some clutch adjustment, but what a pain in the ass. Last year i was driving around with no clutch at all. (from york pa to baltimore and back again) now i got the clutch working ... thank god. Its alot easier to drive these cars with a clutch. (IMG:style_emoticons/default/biggrin.gif)
now the problem is i got all the gears apon startup, but after about 15min of driving first and reverse are no more. I cant even try to get it in without a terrible sound that says NO WAY MAN. so i start out in second and dont even try reverse. But when the car cools off again their back. (IMG:style_emoticons/default/WTF.gif) I already talked to evil, he will help me out to rebuid my tranny, but i dont have $$$ for that yet. Any tricks you guys have for me, am i the only one with temporary gearing. (IMG:style_emoticons/default/confused24.gif) |
Dr Evil |
May 25 2009, 12:53 PM
Send me your transmission! Group: Members Posts: 23,030 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
I told you the clutch was most likely the issue (IMG:style_emoticons/default/wink.gif) I bet the fly wheel was resurfaced and that the TO bearing is not pushing out far enough. It could be an easy fix of a spacer under the pivot ball.......provided you didnt just death blow your gear box.
I am working for the next two weeks and will be busy for the next two weekends. After the 5th I will be free except for the 13th when I am doing a charity ride. I will see about getting you a done gear box as soon as I can and I can come down and install it. You can pay me later. I am offering this because you use your car as a daily driver and your house is close enough that I can stalk you if you stiff me on the fees (IMG:style_emoticons/default/wink.gif) |
jsayre914 |
May 25 2009, 01:14 PM
I told you the clutch was most likely the issue (IMG:style_emoticons/default/wink.gif) I bet the fly wheel was resurfaced and that the TO bearing is not pushing out far enough. It could be an easy fix of a spacer under the pivot ball.......provided you didnt just death blow your gear box. I am working for the next two weeks and will be busy for the next two weekends. After the 5th I will be free except for the 13th when I am doing a charity ride. I will see about getting you a done gear box as soon as I can and I can come down and install it. You can pay me later. I am offering this because you use your car as a daily driver and your house is close enough that I can stalk you if you stiff me on the fees (IMG:style_emoticons/default/wink.gif) (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/av-943.gif) thanks (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 21st September 2024 - 06:58 PM |
