alternator belt |
alternator belt |
jea69 |
May 22 2009, 04:05 PM
doing unspeakable things to iron Group: Members Posts: 51 Joined: 13-March 08 From: norway Member No.: 8,811 Region Association: Scandinavia |
hello i have a question ,my car is twisting and throwing the alt belt, is there a way
to align the alternator without dropping the motor? i have a 1970 1,7 . (IMG:style_emoticons/default/confused24.gif) mid engine blessings (IMG:style_emoticons/default/barf.gif) |
jea69 |
May 27 2009, 12:45 PM
problem solved , po has put the alt pully backside out ,was able to remove the nut
and flip the pully around without remowing the alt (IMG:style_emoticons/default/piratenanner.gif) heres what i did checing alignment: take a round steel bar 6mm (1/2") 35 cm long (check its straight), between the alt and fan pully there is a long stud , let the rod rest on the stud and push it into the fan pully v groove , put the other end on top of the alt v groove , check with mirror to see if it crosses over the alt pully, eaven slight variations will show up this way. (IMG:style_emoticons/default/cheer.gif) |
Lo-Fi Version | Time is now: 24th September 2024 - 01:14 PM |
