Do you know the CA law on swapping motors?, smog |
computers4kids |
Jun 3 2009, 08:10 AM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
If you do a conversion to a 76 car in CA, which requires smog checks do you know how the law works in regards to smog? As I recall there's some fine print if the motor is newer or older than than car it's going in (76)?? I still need to talk to the DMV for their version, but I always like to know the answers to my questions before I ask them. (IMG:style_emoticons/default/happy11.gif)
Thanks |
Cap'n Krusty |
Jun 3 2009, 08:53 AM
Close. I believe the rule is the emissions equipment goes with the engine or the car, whichever is newer. In effect, that basically prevents you from using an engine earlier than the car. The Cap'n, BTDT
EdwardBlume |
Jun 3 2009, 09:40 AM
914 Wizard Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California |
Close. I believe the rule is the emissions equipment goes with the engine or the car, whichever is newer. In effect, that basically prevents you from using an engine earlier than the car. The Cap'n, BTDT This IS true if you do it the right way AND the inspection people know / care. Reasonable (and sometimes unreasonable) things get by. Also, I believe once a year 500 exemptions are passed out in Sac for non-passing unoriginal cars (a friend of mine had a Cobra kit car exempted) but bring your sleeping bag. Lastly, I think what the '76 owner wants to do is bypass smog and enjoy the car. '76 cars currently require CA smog. There's no way around it. The best you can do is fix the pump, give it a shot, and work within the process. Talk with Rich at HPH too. He may have some advice. |
Wes V |
Jun 3 2009, 10:07 AM
Member Group: Members Posts: 482 Joined: 11-October 07 From: Los angeles Member No.: 8,211 |
Here is a link to the California Air Research Board web site.
CARB website About 2/3 down you will find the following section; Engine Changes Engine changes are legal as long as the following requirements are met to ensure that the change does not increase pollution from the vehicle: The engine must be the same year or newer than the vehicle. The engine must be from the same type of vehicle (passenger car, light-duty truck, heavy-duty truck, etc.) based on gross vehicle weight. If the vehicle is a California certified vehicle then the engine must also be a California certified engine. All emissions control equipment must remain on the installed engine. After an engine change, vehicles must first be inspected by a state referee station. The vehicle will be inspected to ensure that all the equipment required is in place, and vehicle will be emissions tested subject to the specifications of the installed engine. Wes |
Lo-Fi Version | Time is now: 6th January 2025 - 07:36 PM |
