Gint |
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,086 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains ![]() ![]() |
I've thought about doing a Megasquirt for a while now to replace my carbs. I have a Mallory that works great, so to keep the initial cost down as well as keep it simple, I want to do fuel only, but have an upgrade path available for ignition later. Ideally if this could be done for under $500 that would be fantastic.
So... What is the easiest, cheapest, most simple solution for induction parts? Throttle bodies, injectors, TPS, etc...? Which MS unit has the flexibility to do fuel now and ignotion later without starting all over again with a different ECU? Engine is a 2056 that is built on a 1.8 case and heads with a 2.0 crank, rods and P/Cs. Currently running dual Weber 40 IDFs. (IMG:style_emoticons/default/idea.gif) (my own note: 40 IDF 70 9A, Italy) |
rick 918-S |
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,512 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region ![]() ![]() ![]() |
I like McMarks test engine idea. Hey, So am I off my nut to suggest using a modern FI off some 1.8 or 2.0 four banger? Find something with a blown up engine and strip the whole thing off including the injectors. Peel back the harness and strip everything that doesn't make spark or fire an injector... Transfer the guts from the distributor of the donor engine. I bet some crafty 914'r could make their engine run. Retain the test port in the donor harness to read and code errors.
I'm putting a 1300 GTI twin cam Suzuki Swift engine in a 1959 Austin Healey. I stripped the harness of all the crap that doesn't make spark or fire the injectors or run the distributor. I'll let you know if I can get it running. It's a slow process for me. I aalways have too much on my plate. Attached image(s) ![]() ![]() |
Lo-Fi Version | Time is now: 25th June 2024 - 08:07 PM |
