Cheap, simple, non-factory FI solution, parts, etc..., Type IV - This oughta be fun... |
Gint |
Jun 4 2009, 04:39 PM
Mike Ginter Group: Admin Posts: 16,086 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
I've thought about doing a Megasquirt for a while now to replace my carbs. I have a Mallory that works great, so to keep the initial cost down as well as keep it simple, I want to do fuel only, but have an upgrade path available for ignition later. Ideally if this could be done for under $500 that would be fantastic.
So... What is the easiest, cheapest, most simple solution for induction parts? Throttle bodies, injectors, TPS, etc...? Which MS unit has the flexibility to do fuel now and ignotion later without starting all over again with a different ECU? Engine is a 2056 that is built on a 1.8 case and heads with a 2.0 crank, rods and P/Cs. Currently running dual Weber 40 IDFs. (IMG:style_emoticons/default/idea.gif) (my own note: 40 IDF 70 9A, Italy) |
edwin |
Jun 5 2009, 06:46 AM
Member Group: Members Posts: 321 Joined: 20-May 09 From: Australia Member No.: 10,384 Region Association: Australia and New Zealand |
if you have webber manifold then bmw bike throttle boddies work great.
http://cgi.ebay.com/ebaymotors/BMW-K100RS-...sQ5fAccessories k100 throttle boddies. similar spacing to webber and around about 40mm from memory. will flow better than carbs as they have nothing inside them. injector ports built in but injectors will be too small. generaly find something with similar size engine and power to what you have now and you will get cose to the mark. junkyards never charge much for them anyway. couple of guys here in aus use Gotech efi which has close loop control of fuel system which makes it much less of a hassle tuning. they are a south african company who started doing vw golfs and have a fair following of aircooled stuff now which is handy for base maps. other brand ecus include Microtech, haltech and autronic. have to give the local produce a good word dont i. if you run electronic poinst replacement then it is easyish to trigger but crank/cam trigger can be more accurate depending on how it is done. many options out there. cheers edwin |
Lo-Fi Version | Time is now: 25th June 2024 - 07:43 PM |
