Tranny Swap, What else will work in a teener? |
ThinAir |
Feb 3 2004, 09:31 PM
Best friends Group: Members Posts: 2,553 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region |
These days I'm driving Mike's 1970 teener since I broke my 73. With no radio I get to listen to the sweet sound of the 1.7L behind me and I get lots of time to think (probably a dangerous thing!).(IMG:style_emoticons/default/wacko.gif)
So I got to thinking about transmissions and I remember someone commenting that there was a cable-shifter available from Patrick Motorsports, but that even though it is better than a stock side-shifter it still isn't as smooth as modern transmissions that were made to be cable-shifted. It being that Kennedy seems to make adapters to fit anything, is there a cable shifted transmission out there that would be a natural fit for a 914? (Of course you probably have to flip the ring gear.) Subarus come to mind as a possibility just because they have flat-4 engines, but I have no idea about anything else about the cars. |
andys |
Feb 4 2004, 02:34 PM
Advanced Member Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None |
The '97 up Passat has a longitudinal transaxle (as does Audi). The 1.8T uses a code EZG (mostly) 012 transaxle, which has ratio's slightly closer than does the 5 speed Boxster. 5th gear (net) ratio's are the same for both. For the Boxster guys; where is the starter mounted on the 5 speed car? Fore or aft of the bellhousing?
Andy |
Lo-Fi Version | Time is now: 24th September 2024 - 12:57 PM |
