Tranny Swap, What else will work in a teener? |
ThinAir |
Feb 3 2004, 09:31 PM
Best friends Group: Members Posts: 2,545 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region |
These days I'm driving Mike's 1970 teener since I broke my 73. With no radio I get to listen to the sweet sound of the 1.7L behind me and I get lots of time to think (probably a dangerous thing!).(IMG:style_emoticons/default/wacko.gif)
So I got to thinking about transmissions and I remember someone commenting that there was a cable-shifter available from Patrick Motorsports, but that even though it is better than a stock side-shifter it still isn't as smooth as modern transmissions that were made to be cable-shifted. It being that Kennedy seems to make adapters to fit anything, is there a cable shifted transmission out there that would be a natural fit for a 914? (Of course you probably have to flip the ring gear.) Subarus come to mind as a possibility just because they have flat-4 engines, but I have no idea about anything else about the cars. |
75boxster |
Feb 4 2004, 06:22 PM
Member Group: Members Posts: 89 Joined: 1-January 04 From: Ft. Collins, CO Member No.: 1,488 |
As far as a TDI goes, if it will bolt up to the boxster,Passat,A4 tranny
you could use that option but I am not sure that gearing would be what you want with the diesel characteristics. Scott(SKSfrom Audiworld.com) put in a 350hp 1.8t with an Audi A6 front drive tranny(similar to the A4's) and used the boxster cable shifter assembly and said that it worked out pretty slick. |
Lo-Fi Version | Time is now: 24th June 2024 - 06:40 AM |
