McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
Since quite a few people were interested in crank fire and aftermarket FI system I finally finished up my crank position sensor setup. So if you want to run distributor-less ignition or modern FI, this setup is the ONLY setup built specifically to bolt onto a Type 4.
It's a complete bolt on upgrade, which means no drilling or modifying any parts to make this work. Only the cooling fan needs to be removed to complete the installation. This setup is great for modern FI system, which need a 'trigger signal'. Fuel only setups usually get their signal from the coil firing, but that signal is DIRTY and unreliable. This crank fire setup is smooth and clean. You can't beat it. There is no other setup built specifically for our motors. Quick easy installation with no headaches. Complete package price is $175 and includes the trigger wheel, the sensor, and the mounting bracket. You won't need to go searching for anything else. Attached image(s) ![]() |
CliffBraun |
Member ![]() ![]() Group: Members Posts: 252 Joined: 26-April 06 From: San Luis Obispo,ca Member No.: 5,933 Region Association: None ![]() |
I have some questions, Looks really nice though.
Is it a hall effect sensor? if so, how do the sections removed for weight affect signal? Also, There seems to be a set of teeth with a way larger gap than the others. What's up with that? As I understand crank position you want to know at least two positions of the crank for a 4 cyl 4 stroke (two cyls fire/crank rotation) I might be wrong though. |
ottox914 |
The glory that once was. ![]() ![]() ![]() Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest ![]() ![]() |
I have some questions, Looks really nice though. Is it a hall effect sensor? if so, how do the sections removed for weight affect signal? Also, There seems to be a set of teeth with a way larger gap than the others. What's up with that? As I understand crank position you want to know at least two positions of the crank for a 4 cyl 4 stroke (two cyls fire/crank rotation) I might be wrong though. Look closely and see that there are 35 teeth, one missing. 360 degrees is a circle. The "missing tooth" is now a reference point for TDC. The programing of the SDS requires a different sensor set up, so this new system may not be of much help for that ECU, but for those looking to do MS, this is the right tool for the job, priced right, easy to install. Great job. |
Lo-Fi Version | Time is now: 2nd July 2024 - 04:20 PM |
